- 159
- 231
- 43
- Las Cruces, New Mexico
Turned out I couldn't find any at all except for a guy on eBay sitting on a pile of surplus NOS and asking $300 apiece. At that price, I got into my junk box, pulled one off a seized DB2, and tried it out. Worked great, and I liked the price a lot better.Was really looking forward to how cheap parts would be on a truck that has had overstock sitting on shelves for decades all over the world. Also, in case anybody wondered, the black plastic vacuum doodad on the side of your injector pump is GM #14057219 aka NSN #4820-01-158-6836. Nobody is making them and NOS seems to hover around $200 USD at a minimum if you can even find one.
I've got one practically brand new if you want it. I'm not going to need it with my new 765R4. Pm me if interested.Was really looking forward to how cheap parts would be on a truck that has had overstock sitting on shelves for decades all over the world. Also, in case anybody wondered, the black plastic vacuum doodad on the side of your injector pump is GM #14057219 aka NSN #4820-01-158-6836. Nobody is making them and NOS seems to hover around $200 USD at a minimum if you can even find one.
765R4 sounds sweet. I had to look it up. Check that pinned thread on CUCV hot rodding before hooking up the kickdown cable, and PM sent!I've got one practically brand new if you want it. I'm not going to need it with my new 765R4. Pm me if interested.
That magic spring did come out of your steering column...it's the key in the ignition ground...I usually chuck those since I don't like that buzzing noise.I actually hadn't installed the upper shackle bushings on the front end, so I set about that this morning. Had spent some time looking around online for any example I could find of how it's done, since I don't know what I don't know and that's a good way to find out. No luck, so here's my experience. First, set up some kind of heat deflector above the driver's side upper, because torching it could catch your wiring harness on fire if you don't. Other than that, I just heated the center sleeve, twisted it out, cut off one side of the rubber, and knocked it through from the outside with a screwdriver. There was no outer sleeve, which was a relief, because I had set up my reciprocating saw and discovered it was not going to fit before I got started.
So that one's in place. Stopped there, since my favorite neighbor came out to let me know what he thought of the sound of bushings being tapped with a hammer. Figured since I was rolling around in the dirt anyway, I'd get a pic of the transmission mounts I did a couple days ago.
My undercarriage is beautifully seasoned, like an heirloom skillet. I had wanted this thing for awhile and finally decided I was willing to buy once and cry once. I'm happy with it. Good purchase.
Yeah, I know, plywood or something. Haven't got any. The truck can't push this jack frame through the sand. My house is built on it. It's fine. Anyway, I found some kind of sprung push retainer on the driver's side floorboard yesterday and I don't know what it is. It could have fallen out of the steering column when I was tapping the lower column onto it. That's my only theory. Does anyone recognize this thing? Thanks in advance if you do.
Hey, thanks! No wonder I never missed it. Glad to know I don't need to worry about it.That magic spring did come out of your steering column...it's the key in the ignition ground...I usually chuck those since I don't like that buzzing noise.
I've got a bunch of rims plus one brand new one...I get them whenever I can. Since I have 3 it's good to have spares. Look on marketplace for a 1009 part out. That's where I get mine.Slaughtered the budget this month ordering this bumper with a jerry can carrier. Made to order and turnaround is lengthy, so I have time to think about what I've done. If anybody's got an extra M1009 wheel, let me know. Hillbilly Wizard is asking more than I want to spend for a matching spare, considering I've already got a proper offset steel wheel to work with. Just a matter of dollars versus how nitpicky I'm feeling, I suppose.
