264Charlie's M51A2
264charlie
32
Gainesville, TX
Hi all, I just picked up an unseen M51A2 from an auction site. It was a bit of an impulse purchase that resulted in about 50 hours of research, during which I'm much more educated about what I bought. I purchased the truck to move about 250 yards of dirt around my property. It should be a fun journey.
264charlie
32
Gainesville, TX
Does anyone have a recommendation for axles and brake rebuilt kit vendors? Or are the big ones that pop up on Google the best route to take?
20,396
I just got home and took a look at the M51. Well... the "All wheel drive. Starts, runs, drives and dumps well. This truck is ready to go" is a drastic over-exaggeration of reality. 50/50 If I'll part it out or get it going.
That sounds pretty sad. I mean the paint job looks really nice. What about the internals? Are the Gear boxes, Motor, and Brakes okay? Or are at least some of the parts good?
fuzzytoaster
3,476
Fort Worth, Texas
Send it back and get your money back. They're all GSA Arkansas turn-in trucks..
NDT
7,076
Camp Wood/LC, TX
Dump trucks are always worth more assembled than in parts. Wow the picture you first posted sure did look good except for the ridiculous stenciling. They call that “lacquer overhaul” in the construction equipment biz.
264charlie
32
Gainesville, TX
100% a lacquer overhaul with bad stenciling.
After much thought, I have a path forward. While it will be more expensive than I initially estimated, I am confident that the result will be something useful that I'm proud to own. When done, it's going to be a 25k—45k truck. I'm not sure I'd ever get that out of it, but I'm sure I could get .50 cents on the dollar.
Project goals:
- Trucking of gravel, dirt, trash, and scrap runs, 7 - 10 miles on back roads.
- Support a tag trailer to move the backhoe (around 8.5 Tons)
- Local pickup of heavy junk; I typically buy it within 150 miles
- A front Jin (a frame) poll would be a good idea for general use around the property if I could make it work with the dump.
- Just owing a 5-ton is fun, so I'll run with it, lol
Phase One: Functional, approximately $6K+ (I can fund this now)
- Axel Seals, bearings, and fluid changes. $1,500
-- I'm not sure I'll need bearings. I should do it if I have them apart, right?
- New Batteries plus install master shutoff switch $500
- Electrical 12v and 120AC in the cab $200
-- got to charge the phone and laptop
- Brakes $2,000
-- Replace/rebuild everything
- Dump cylinder rebuild & fluid changes $350
- Fuel system clean out, refresh $500 - $2,000
-- tanks, filters, lines, injection pump, injectors
- Fluids, filters, air system, services + misc issue that pop up $500+
Phase two, Comfort & Safety. Approximately $12K (If I sell my dump trailer, I can fund this)
- Shocks $900
- Electrical check, keyed ignition, lights, gauges, 12v trailer hookup, etc. $550+
- Weatherproofing. $2,500
-- Windows, seals, hard top
- Recovery $500
-- Tools, Tire repair, straps, jacks, and chains...
- Tires and wheels $3,500
--I will likely go with 395/85R20 because I like the looks, don't want 53s on a dump, and 14/20s don't seem as available.
- Seats $1100
- Center console, radio, comms, $500+
-Cab heat $500
Phase Three, Want list 19k+ (most likely will not get done anytime soon)
- Engine rebuild $2,500+
- 10 Speed trans swap & $2,000
- Rear lockers $2,500
- Paint $2,500
- Front winch, Jin Poll $3,500+
- Diff E-brake, maybe, it seems like it might be a good idea $500
- Air brakes $3,000
- Deep Water Kit $250
- Lighting and accessories $500+
- Locking Front Hubs $1,500
264charlie
32
Gainesville, TX
Well, I flushed the primary tank and put in two new batteries, and the truck fired right up; the downside was that it had a fuel leak in the engine compartment, spraying fuel everywhere in a fine mist. At this point, I figured out that the truck did not have a primary or emergency engine stop. I tried capping the intake with no luck, so I cut the fuel line. Fun times.
I hope to fix the fuel line this weekend and make a plan for the fuel cutoffs. I started looking through manuals to find out how they should be run, but I haven't found the answer yet.
I should have just stalled the engine. Dang it. Hindsight.
264charlie
32
Gainesville, TX
Your truck has a multfuel engine essentially the same as “deuce” trucks. The engine shut off system has probably dozens of threads on here as it causes issues.
Yep, I'm aware. Mine is missing the levers in the cab, so I am looking to see how they were initially run to the pump.
Valley Rock
Big wheeler cat peeler
867
Orygun
These old trucks always need work, whats so bad about it ?
4k to your door seems like a decent deal to me, at least its a 5 ton .
