Spent time today tracking down my a/c leak - more like huge hole. Exhaust burned the a/c line completely through - anyway, I’ve spent the last hour or more pouring through TM’s and no luck getting the correct hose part number. Is there a special TM for revb a/c? I found the supposed correct part number for m1151a1 but the hose is different. Mine runs directly to the low side from the center inside condenser (correction : evaporator) - seems like 1 hose, not split? Unless I just can’t see a junction. Has a bent condenser fan on right rear as well, I’ll try to repair that I guess. Also - is the UOC for a revb M1151a1 TTA? I feel like it would be different.
