M1151a1 revb a/c hose
mrfarb
164
33
Texas
Spent time today tracking down my a/c leak - more like huge hole. Exhaust burned the a/c line completely through - anyway, I’ve spent the last hour or more pouring through TM’s and no luck getting the correct hose part number. Is there a special TM for revb a/c? I found the supposed correct part number for m1151a1 but the hose is different. Mine runs directly to the low side from the center inside condenser (correction : evaporator) - seems like 1 hose, not split? Unless I just can’t see a junction. Has a bent condenser fan on right rear as well, I’ll try to repair that I guess. Also - is the UOC for a revb M1151a1 TTA? I feel like it would be different.
mrfarb
164
33
Texas
Thanks. My neighbor suggested having it repaired. Plenty of hydraulic hose type repair shops in this area. Regardless I guess I’ll plan on removing it and finding the part number that way.
G550
15
SW Florida
I second what your neighbor suggested. Maybe an industrial AC repair company also. They both should have the hose to re-crimp the ends on.
Gcelevator
706
Fort Lauderdale, Florida USA
Have the hose made locally. I did all mine with the original fittings from the old hoses and so far they are really good. Cheaper than trying to source the original parts. You can even install extra protection so it won't happen again.
mrfarb
164
33
Texas
Is part #13 what you’re looking for?
View attachment 926945 View attachment 926946
I thought so, but if you look up the hose it’s short and runs to a connector, also shows a red high side cap - this one runs from the condenser to the evaporator inside the truck (notice the parts manual doesn’t have the other numbered). I’m going to pull if off and have one made, seems like the best course according to experience here.
Retiredwarhorses
4,181
Brentwood, Calif
The part number is on the hose generally, at the component end…you won’t fine a shop that has those wonky ends AMG used.
one thing I like about the dual barrier ac hose is that I can use EZ clip anywhere, these trucks use single barrier hose and that means you can only
Use compression crimp connectors.
i have pretty much every hose in stock for these trucks
Gcelevator
706
Yep, I did all my red dot lines locally. Easy peasy and some people say that the easy clip holds better, I am not expert in the matter.
REF
127
Porterville Calif
I think your looking for #11 P/N 6015457 Runs from the seal plate for the front evap to the rear center mount evap.
Edit: Kascar real 4wd has it for $76.44 and a picture of it on their site.
mrfarb
164
33
Texas
Sure looks like it! I’m going to pull it off to verify, thanks a million!
mrfarb
164
33
Texas
Update - pulled the hose out (in 2 pieces), you nailed it. It actually bolted to a connector near the front evaporator as stated, not directly to the compressor like I thought. I’m gonna have to lift the body to get it back where it was…..
Mogman
9,583
Papalote, TX
Do not forget to replace the drier, this is a must do step.
