- 117
- 316
- 63
- Albany, NY
Mercedes Type C winch. I have one, and up until a few days ago I didn't know a darn thing about it except that it looks the part. So I learned a little about it, and tested it out. Very glad to report it works as advertised, but I was a little sad that the manual calls for two man operation. I'm only one man most of the time, and operating the winch requires some hopping in and out of the truck. Here's what I learned:
There are no official English translations of the manual. So I read threads, and eventually found out that the Type C winch is PTO driven. It only powers in, it does not power out, although I have a brake so I can lower off heavy objects. But the cable must be pulled off the spool.
To operate it, start the truck. On the top of the winch there are two levers. The longer one is the brake, sprung into the off position, and a selector handle that is labeled EIN and AUGHT which means in and out. Move the lever to the AUGHT position. This releases the spool. This can be problematic, both getting the lever to shift and then getting the spool to unwind initially.
Pull off the amount of cable you need and secure it around something solid. Go back and get in the cab, set the hand throttle at a high idle and push in the clutch. Take the main shift lever and push it over into the high range neutral, as if you were going to try to start in 5th gear, but leave it in neutral. Release the clutch. You will hear the engine change pitch. Then push the clutch in again, and pull up on the PTO lever. You will hear the PTO engage and start spinning, and feel it too.
Now slowly release the clutch. You will see the winch spool start to turn and if you release the clutch completely the motor takes the full load and you start winding in. You will drag towards whatever you are hooked to.
Once you are winched in, press the clutch in again, and push down on the PTO lever. Then release the clutch and you are done.
The gears sit in a bath of gear oil (makes sense) and I topped it up. Painted the winch and bumper, and put the cable guide back on.
![IMG_20240707_164727566.jpg IMG_20240707_164727566.jpg](https://www.steelsoldiers.com/data/attachments/682/682927-4d545cdf9a51be18f5f4140e1147f9f3.jpg)
![IMG_20240707_203203423.jpg IMG_20240707_203203423.jpg](https://www.steelsoldiers.com/data/attachments/682/682928-4c68c607860caaae7706e429350d3c9a.jpg)
![IMG_20240708_114210307.jpg IMG_20240708_114210307.jpg](https://www.steelsoldiers.com/data/attachments/682/682929-3ee49246561c93d7d988ef0051901c10.jpg)
