Valley Rock
Big wheeler cat peeler
863
Orygun
If you just use your bottle jack and lift it up just a minimum to where the the wheel is loose on the studs, you can just walk the wheel right off and roll it over and lean it up against the truck you won't need all that cherry picker business
The Jack stands you're trying to use are way too tall in my opinion, the bottle jack should hold it just fine while you do what you need to do don't stick your hands underneath it
If you don't like that or have safety concerns I'm sure you got a stump or some blocks of wood or something around there you can shove under it
Wreckclues
665
Jefferson, Massachusetts
Alas theory and practice don't always lineup, will have to jack her up about 7 inches to use this method. How much of a hassle is it to singlehandedly manhandle one of these into place? It didn't seem that heavy getting off the pallet and rolling around.
jcollings
402
Jupiter/FL
It's easy just put it on the ground roll over to the truck keep it balanced and lean it against the Hub studs, slowly Jack up till you get a thread and put it in place. get it on there you're done. You can also use a long bar underneath to pry it up to get those studs in place.
Sent from my SM-G975U using Tapatalk
Wreckclues
665
Changed the front tires yesterday.
The left front wheel had dry-rot in it so had to replace both wheels.
Was easier than I thought, no shmancy tools just a jack, an impact wrench and a lot of penetrating oil, only took about 15 minutes per wheel. The hammer mentioned in the tools photo was used to set the other wheel, which I didn't tape.
Here's a 3 minute video set to a familiar theme.
msgjd
3,619
upstate ny
I changed the horn solenoid still no clunk or Horn. Pulled out the horn button being very careful not to deploy the airbag lol. The steering nut is all rusty I’m thinking a new nut and horn button might fix it if not I’ll get a hand held air horn.
A bicycle squeeze horn clamped onto a mirror bracket is an OEM option ! ;) :D
hgun
372
Leechburg, PA
I didn’t think of that horn, one with Cookie Monster on it. I did get it fixed replaced horn button etc in steering wheel. But I got a puzzling thing going on. I fixed some brake lines added the remote reservoir to keep an eye on fluid, bleed the brakes all wheels. All good toped off the reservoir took it for a ride brakes put you through the windshield. Did couple laps around back roads, parked it next time went out the reservoir was empty. I’m thinking leak I crawled all over under around checking for leaks nothing is dripping or wet. So I refilled the reservoir and drove it some more was working on a coolant issue. Any way the reservoir was full. Tonight I went out to put the batteries on charge and glanced at the reservoir it’s half empty, I looked all over again nothing. I’m lost on this one. Is it possible it’s still working out air Somewhere? Any ideas on what to check. Thanks guys.
Wreckclues
665
Found my new favorite toy...
No hammering away at the tire to break the bead just brrrrt, brrrt and she's off. Also loosens the ring.
Now I have to walk the ring off.
This is a Vevor, the model is pretty much standard with all manufacturers.
Hardest part was starting the first break, getting the claw to grip in the bud hole, once started the rest were easy.
Valley Rock
863
Orygun
I put my towbar on the rear of my truck backwards .
I made it to where the loop just barely slips over the top when you push it forward, it's never going to come off unintentionally .
I saw a guy pulling a tank around with this method, and though I do not have a tank as of yet, I just wanted to see about the fitment and make sure it would fit, for when I get a tank .
And the other reason would be that I had nowhere good to store it, and now I know where it's at .
msgjd
3,619
upstate ny
work smarter not harder ;)
i have a "little buddy" like that made by AME... Been a lifesaver with tractor, payloader, and grader tires.. in the fine print it says it's okay to use manual or power tools, but not an impact, although tempting as it is ! :D
Joe Bertram
366
Indiana
Been working on getting the M-51 ready for painting. Mad dash just a couple of weeks to get it done for the Portland Indiana MVPA show. Got them all lined up along the tracks so I have room to start painting next week. Nevermind the bobcat and the bucket truck lol
