Renee
- 20
- 3
- Railroad Flat, CA
Hi Guys-
I have a 802A and a 803A both down due to radiator issues. leaking at the header from corrosion.
Quote from a local radiator shop to re-core is $700 + tx....ouch...way to much....
I have been thinking on using a radiator out of a VW, bad news is the core is 12"x 17" or 12x 20.5", good news they are dual pass and the I/O are 1 1/4¨. I can fab an inlet M22x1.5 to 1 inch nipple and use a Honda or Suzuki fill port cost is under $150 plus time
so the mod is flip 180 degrees make mounts and fill the space above and below to mount the shroud on the 12x17 rad and just let the air flow do its thing .....most likely fine for the 2 cy 802A.??????
.... but the 803A what to do?...
someone with some thermal design background?
If I use the 12x20 it will require a new shroud and cut out the opening to accommodate width for air flow- may have to move the fuel pump and coolant overflow if much total OAW of 23¨
oh other option is Griffin or other custom shop to make rad
the issue is as told to me 16x16 core is not available ( at least is AL)
I did find a poor quality drawing with physical specs.
Specs on OEM Rad
core 16x16 x1.57 inch
2 row 36 tubes
fins are 8 to 12 / inch
Thoughts are greatly appreciated.....as fire season is here in CA.
Thanks
Renée
Specs on OEM Rad
2 row 36 tubes
Thanks
Renée
