HEUI Troubleshooting - Injection Pressure Desired and Actual Mismatch
GeneralDisorder
5,772
Portland, OR
The turbo exhaust gasket that CAT gave me was fully rectangular without the bolt "bumps" on the short sides. Probably irrelevant. Make sure it's got a fire ring though. It's going to see ~60 psi of pressure.
Keith Knight
2,070
Wauchula, FL
I’ll visually look at the existing gasket. It took forever to find that thing. It was in a turbocharger install kit from cat and in the kit all the o-rings and gaskets that I had posted in the image earlier. Which gave me confidence that this is correct for our engine. Plus the last image it says factory fit 3126 with my engine serial number.
GeneralDisorder
5,772
Portland, OR
Yeah looks right. Just not what they handed me. Probably you'll get the same thing I got. End of the day it's a standard T3 divided port turbo gasket. They are under every rock from a million suppliers.
Keith Knight
2,070
Wauchula, FL
They look like the are sold in many thickness variations from single sheet metal to multi layers to cat design.
GeneralDisorder
5,772
Portland, OR
You want an MLS (Multi-Layer Shim) style WITH a fire ring to prevent the exhaust gasses from working their way between the layers. If you want a really high quality (better than CAT) alternative, this is one option:
aw113sgte
1,308
La Crosse, WI
Tried the SIS 2.0 on the website, pretty lacking in some details, but actually seemed to use my trucks serial number instead of saying "can't find" like the main parts search. (this is for a C7). However, there are two options shown with different quantities.
Keith Knight
2,070
Wauchula, FL
Thanks, With all the parts individually I plan to go to Cat tomorrow and see if they have a kit that has most of the parts then purchase what’s missing individually.
