- 982
- 1,838
- 93
- Wauchula, FL
Mine is definitely a one piece filter housing.
There's two of one gasket - block to spacer, spacer to cooler. And one of the divided gaskets - cooler to filter head/plate.It looks like the spacer is still attached to the cooler? Isn't there a gasket between the cooler and spacer?
You want an MLS (Multi-Layer Shim) style WITH a fire ring to prevent the exhaust gasses from working their way between the layers. If you want a really high quality (better than CAT) alternative, this is one option:They look like the are sold in many thickness variations from single sheet metal to multi layers to cat design.
