Caterpillar 3126B oil cooler problems
hike
—realizing each day
824
Texas Hill Country
Thank you @Keith Knight, and everyone else for thoughts and questions. While I would prefer not to do this you have pointed out that for some time and a couple hundred dollars this is a maintenance task level project.
Where did you find torque specifications and such? I recall having books on all our CAT equipment we used, though that was 30 years ago—
hike
—realizing each day
824
Texas Hill Country
Well the IFS filter is the real protection IMO, even thou I've not bought one yet. I'm Saving up lol..
The IFS is the high pressure filter on the HEUI output? Since I haven't kept up on this issue: filtering after the HEUI pump is better than before? or simply the best place to add a secondary filter?
Next question is for the time and money, isn't replacing the oil filter housing gasket best? Do we need secondary filter after replacing the gasket?
Keith Knight
1,784
Wauchula, FL
On our 3126B we can’t put a filter before the HEUI pump so putting after protects the injectors and everything else after that. Basically preparing for the HEUI pump to fail. Replacing oil cooler and filter housing gaskets and if needed a flatter oil cooler or machining it flat what ever you decide. But the IFS kit is cheaper than replacing all the injectors. Replacing the HEUI pump is something that I could do on the side of the road if necessary. But replacing the HEUI pump and injectors on the side of the road not so doable. In my opinion.
Keith Knight
1,784
Wauchula, FL
I went with standard torque ratings for M8 bolts. For the filter housing and everything else is like alternator bolts and brackets I just tightened by feeling! LOL!!! Exhaust nuts tighten them really good too. 😂
Also while I was working on it I discovered some soot near the exhaust manifold and block closest to the transmission. Turns out I had a loose exhaust manifold bolt.
Also found a missing bolt that holds the intake tube to the block. Just saying keeping a clean motor and looking for leaks or anything else on a regular basis prevents bigger problems in the future.
GeneralDisorder
5,009
Portland, OR
As with all engines - the main engine oil filter is not full flow. It is bypass filtration. So under MANY conditions the engine is already getting unfiltered oil. If the oil is cold, especially at high RPM (see ECO hub discussions), and if the filter element is partially plugged. If the differential pressure across the element exceeds the bypass spring rating in the filter head, it bypasses the filter on the principle that unfiltered oil is better than no oil at all.
The HEUI pre and post filters are FULL FLOW. In other words oil is not allowed to bypass them at all. Oil must flow through the filter or whatever is downstream from them receives insufficient oil.
Ronmar
7,222
Port angeles wa
Yea you could have a perfect oil filter and cooler assembly, but a HEUI pump failure is probably going to wipe the injectors also…
our main oil system actually has 2 bypasses in it. One pre-cooler, the other pre-filter..
Keith Knight
1,784
Wauchula, FL
Also found a missing bolt that holds the intake tube to the block. Just saying keeping a clean motor and looking for leaks or anything else on a regular basis prevents bigger problems in the future. The Gen 2 version has a filter indicator. IMG_3896.png
Lostchain
571
Portland, OR
This post filtering (and the restriction that creates) is known to have absolutely no effect on the HEUI system? Is there any CAT documentation about this modification?
GeneralDisorder
5,009
Portland, OR
The HEUI actuation pressure sensor is located in the cylinder head HEUI oil passage and if the filter system was some kind of restriction to flow it would cause a fault on the ECM as it tries to control pressure through the HEUI injection actuation pressure control solenoid on the HEUI pump. There is no documentation I'm aware of from CAT but the system is very popular on HEUI engines in lots of application - trucks, busses, RV's, and equipment. You can always call and talk to George the guy that makes them. Since the 3126 injectors are $1,000 each and this filter can prevent them from being contaminated by a pump failure.... you are looking at saving roughly $5k in the event of a HEUI pump failure.
That said - both of the 3216's I've worked with that had HEUI failures did not have the injectors replaced and they run just fine. Oil looked very clean in both situations and I have my theories as to what actually is going on (IE: HEUI pump isn't actually making a bunch of metal contamination and the failure is related to pressure regulation issues) but as yet have not confirmed the exact cause of these problems.
MatthewWBailey
Father, Husband and Barn Hermit
1,399
Mesa, Colorado
I'm just bringing up the rear since this has been answered above. The IFS is a post HEUI filter. The pre filter from CAT doesn't fit a 3126B and only fits a C7.
I'm curious if and why people are not adding the typical 2um bypass filter on these? I put the large Amsoil unit on there using the oil sampling port at the cooler, returning to the block port on the rear starboard side. I noticed most commercial trucks run some sort of bypass filter, luberfiner etc. seems more bang for the buck over the long run.
custom bracket required, which I'm getting good at. Rick knows the saga of how I removed the lifting cykinder
Keith Knight
1,784
Wauchula, FL
Post pictures of your amsoil filter and part numbers. I’ve considered it but running out of room in there.
MatthewWBailey
1,399
Mesa, Colorado
View attachment 932429View attachment 932430
of course the chosen location is benefitted from me rerouting my exhaust straight back and up, so you can see there's lots of room next to the engine there.
better picture with all the heat shields etc...
Keith Knight
1,784
Wauchula, FL
I thought something was missing. So with that and I’m assuming you use full synthetic oil? What kind do you use? What are your oil and both filters change intervals?
GeneralDisorder
5,009
Portland, OR
I have the same filter but yet to install. Might do it on the passenger side.
Personally I run Amsoil 15w40 Signature Series diesel oil. And oil changes are guided by analysis.
MatthewWBailey
1,399
Mesa, Colorado
Same as Rick said. Amsoil 15w40 Signature Series, and the Amsoil full flow filter. I doubt I'll be pushing beyond 5k miles in a year so IDK on intervals. I gotta see how much oil consumption there is.
Keith Knight
1,784
Wauchula, FL
With this latest oil and filter change I still use the cat filter but I switched from rotella t4 and 1qt of Archoil additive to only full synthetic rotella t6. My oil changes have been around 10,000. That’s about every 6 months.
