th400 help with bolt identification SOLVED
WWRD99
1,715
York Pa
Ok I'm going off old memory but I thought those bolts held the pump together. For some reason I remember those lines cut out on the heads for them.
Lothar
661
North Arkansas
I am beginning to think these bolts are not from the transmission at all but have no idea where else they could be from. I believe the pump bolts you are referring to are pictured. I did not have to open the pump up. But I thank you for trying, I clearly need the help.
WWRD99
1,715
York Pa
Oh if you didn't take the pump apart then it could be the bolts that hold the pump in the case. I got one with those type bolts in it.
Lothar
661
North Arkansas
Those do look the same but these are 1/4" and there are only 3. I tried to DM @cucvrus but I think his notifications might be off. Thanks again.
WWRD99
1,715
York Pa
Although they don't appear to do much, the mystery bolts go in the back of the center support. Thanks all for playing.
Haha there it is! You need those! Glad you found it
