- 307
- 845
- 93
- Utah, Murray, United States
Out for a warm up and a full fuel top off. The BOT is awesome. Excellent rig.
There is a great video done by yhe Western Canadian Rockwell guys on Youtube on how to do a chunk inspection. In yhis video they cover the details on a 2 1/2ton chunk but point out along the way yhe differences with the 5 ton. Very helpful.Is there any shimming to do after the swap or is it just a carrier change over?
No kidding this was a bit much to bite off, but was able to punch the leaky inner seals out, replace the boots and put the locker into the chunk clean everything up on the top loader, reinstall the chunk and do some clean up of tools etc... On Saturday Looking to finish. Will be getting the axle back under, get the new inter seals installed, replace all the brake lines, drums back in place among a million other things.It feels good watching other people tackle hard projects and make progress all from the safety of my phone...hehehe.
Keep it up!
The front is at 60 and the 4 rears are at 52. My tires were new with the fuzzies on them and I found that running anything more than this that the tire side lugs were not wearing the same as the center section of the tires. When at the above psi the side fuzzies began to wear evenly with the rest of the tire. Now that was with the bed empty and no S-280 shelter in it. But I haven't adjusted the pressure since. If you don't have fuzzies to wear off your tires you can put some paint or heavy chalk on your tire in a line across or on several of the lugs and see how the chalk/paint wears off as you drive. You want it to be as even as possible to ensure full contact of the tire for the longest wear life.What pressures are you running front & rear?
