Rear AC/ heat on 2007 m1151a1
fastmaxx09
South Carolina
I have a a possible issue. My rear AC blower works great on AC. When I switch it to heat, only the front dash blower works. I haven't had to use the heat yet, so my question is , should the rear blower work when I turn on the heat, or is it just for cooling ? I would assume it should work as it does when I use the ac , but it doesn't blow when I switch it to heat .. The front works fine, just not the rear
maxpower_365
9
Spokane, WA
I just bought an M1152 (my first Humvee). The AC doesn't work on it and only the high speed fan works (low speed doesn't seem to do anything). Could someone direct me to the right TM to start diagnosing the issue?
Greg841
70
13
WI
I had the same fan speed problem on my 1151, ended up being the resistor behind the instrument panel. The part number was 5578307. I've found the parts manuals and diagrams are equally useful as the training manuals, the diagrams let you see what's in every system so you can start to narrow down what may be broken.
maxpower_365
9
Spokane, WA
Thanks for the info on the resistor. Looks like I can buy one through HPG for $160. Is that the best place to order one?
maxpower_365
9
Spokane, WA
I finally found the TM with the diagram of where the resistor is. I know you said behind the instrument panel, but a picture is worth a 1,000 words. Thanks again!
