Crig
- 8
- 3
- Pennsylvania
My 6.2 has a blown head gasket which I’m gonna use as motivation to swap to a 1996 6.5T someone local to me is selling for $1,000 but I’m curious what exactly I have to do to make that work?
It’s out of a Chevy pickupNeed to know what the 6.5 is out of, pickup or van/bus? The pickup 6.5 has the side mount turbocharger and that won’t fit in a HMMWV. Electronic injection pump has to be replaced with mechanical.
Is it possible to reconfigure it to the proper turbo set up or is the pickup 6.5 that different from the military 6.5?You can use the pickup truck longblock but you have to ditch the turbocharger setup and reuse all the 6.2 exhaust and intake manifolds.
The heads on the pickup version of the 6.5 are different than the van/bus/H1/HMMWV version, the intake ports are at a different angle. You can use the pickup SHORT block but that is getting you into a lot of work.Is it possible to reconfigure it to the proper turbo set up or is the pickup 6.5 that different from the military 6.5?
But you also must build it as a NA as the pickup block does not have the pedestal for the center mount turbo fully machined.The heads on the pickup version of the 6.5 are different than the van/bus/H1/HMMWV version, the intake ports are at a different angle. You can use the pickup SHORT block but that is getting you into a lot of work.
