Military to Civilian Engine Swap Questions
Crig
Pennsylvania
My 6.2 has a blown head gasket which I’m gonna use as motivation to swap to a 1996 6.5T someone local to me is selling for $1,000 but I’m curious what exactly I have to do to make that work?
NDT
7,076
Camp Wood/LC, TX
Need to know what the 6.5 is out of, pickup or van/bus? The pickup 6.5 has the side mount turbocharger and that won’t fit in a HMMWV. Electronic injection pump has to be replaced with mechanical.
Crig
Pennsylvania
It’s out of a Chevy pickup
  • Like
Reactions: 98G
Crig
Pennsylvania
You can use the pickup truck longblock but you have to ditch the turbocharger setup and reuse all the 6.2 exhaust and intake manifolds.
Is it possible to reconfigure it to the proper turbo set up or is the pickup 6.5 that different from the military 6.5?
NDT
7,076
Camp Wood/LC, TX
The heads on the pickup version of the 6.5 are different than the van/bus/H1/HMMWV version, the intake ports are at a different angle. You can use the pickup SHORT block but that is getting you into a lot of work.
Mogman
10,158
Papalote, TX
But you also must build it as a NA as the pickup block does not have the pedestal for the center mount turbo fully machined.
Now since you have a basic or A1 machine and if you do not care about future A/C etc, I believe some have managed to install the truck motor basically as is with some compromises as to exhaust clearance and some others.
If you want to explore that route I can move this to the appropriate forum.
