- 834
- 1,309
- 93
- La Crosse, WI
He won't get a straight answer because there isn't a straight solution. Depends on the state your carrier which person you call. I called progressive to try to insure mine and they said they absolutely cannot do it, then I happen to mention USAA and then the situation apparently changed, they said if you're a USAA member they have a special group that handles USAA policies under progressive and they could do it.
FYI mine is a 2007 MTV (the 6x6 version)
