Rodburner
- 44
- 13
- NW Oklahoma
I disconnected the jumper and connected both wires going to the oil pressure switch together. Generator fired up quickly. Thanks all for getting me this far along. Will any oil pressure switch work or should I use a specific one. Green Mountain shows one for $77.00 but I thought that was a little high. Let me know. Also I let the generator run for several minutes so not to be starting and stopping, noticed before I shut it down the voltage had dropped to zero. Planning to get the Kill-o-watt device to check frequency but haven’t had anything connected to it except for a led light while testing it. Your thoughts? Thanks again, need to put it up for tonight.
