LMTV Air Conditioner
GeneralDisorder
5,770
Portland, OR
Yeah that's essentially exactly what I posted above. You still need the transducer and charge sensor - whatever those are - and neither lists specifications so you still need to contact Red Dot.
jpelc
25
Madison, Wisconsin
The RD part numbers are included on both schematic and harness details.
Charge sensor is just a low pressure sensor PN: RD-5-9165-0. Its a two contact on/off low pressure typical AC switch.
High Pressure switch is more specific as it is 3 wire sensor with reference 5V, ground and signal: PN RD-5-9254-0.
As suspected, the Protecht Module will not power on the compressor until the conditions are right. Must have all the the sensor working.
Another Ahab
4,694
Alexandria, VA
Update!
Attempted to connect with RedDot with no success. Turned to MME, where I bought the newer GEN II unit and pleaded with them to request the diagrams from RD.... success! Got the wiring and harness diagrams. Christal Clear! I see the light.
I am including it here so to help all.
It's Christmas! It came early!!
