2Pbfeet
- 1,164
- 93
- Mt. Hamilton, CA
Thanks. My bad. I did know that. CRS strikes again.Head glow plugs can't be wired in series since the thread in the block is ground.
Sent from my SM-S908U using Tapatalk
No worries, the reason the manifold heater gets away with it is due to them both being isolated from chassis, then jumped.Thanks. My bad. I did know that. CRS strikes again.
There are a few ways to make it work but if the proper parts are available then there's no sense in rigging it. If you have an overwhelming need to rig it let me know I'd be glad to share my electrical ninja abilities
Not sure where I got them but found them for $15 a few years ago. I also seem to remember a place called Race Mart having them a long time ago.Has anyone seen the CH49 glows for the intake anywhere?
Here’s my plan:
1. IP: remove, disassemble, clean, inspect, reassemble and reinstall.
2. Injectors: remove, see if a local diesel shop can inspect, clean, and test them then reinstall.
3. Remove and replace Glow Plus and Manifold Heaters as a preventative measure.
Questions:
I didn’t want to sound like a broken record but again, thank you all in advance. This Forum and its Members are an invaluable source of information and help for me and others!!!!! Once you get into it, if you have questions you can email me directly or if you're totally lost I will give you my # and you can call me.
- Can I /Should I use CRC Knock’er Loose on all “connection threads” for the Injector Nozzle Assemble, IP, Glow Plugs and Intake Manifold Heater Plugs? There’re pretty corroded.
- Since this IP and Engine have run fine in the past do I need to worry about any “Timing” issues or do I just need to turn the flywheel clockwise until the “PC” mark on the flywheel lines up with the Timing Pointer (and leave it there) in order for proper remove and reinstall of the IP? Put engine at TDC compression on #1 with the pointer on the PC mark and insert a 1/8" drill bit into the hole in the left side of the IP through the flat head screw plug hole. It should slip into a notch in the side of the IP drive gear. By slightly rotating the blower wheel back and forth you will feel the drill bit move a little if you're in the slot. To be sure, look at the pic. I sent you yesterday showing the orientation of the cam lobe after you remove the pump. If your cam is orientated different you are 180* off.
- Should I give the IP (and Injector Nozzle Assembles) an Acetone bath while whole or after disassemble or both? Take it apart and then clean it.
- What IP parts (i.e. O-Rings) should I for sure replace during reassemble? Most likely the plunger guide is damaged. Also you do not need the $50 delivery valve spacer, it is not needed when reassembling the IP on a bench and really serves no purpose other than to help install the delivery valve with the pump sideways.
- Does anyone have any recent experience getting parts from Ambac directly? I’ve read mixed Posts. They stopped selling to the public a good 5-6 years ago. For a while they would still sell to "previous customers" but that has also stopped. This si why you find the conflicting info, the "previous customer" loophole....
- Any suggested sources for IP parts, Injector Assembles, Glow Plugs and Intake Manifold Heater Plugs other than Ambac, GMG, or eBay? Unfortunately GMG and ebay are the only quick source. Ambac told me I could order through any of their authorized dealers, but the 1 I tried wasn't interested, so GMG it was....
- Any other “Tips & Tricks” you all would suggest? Take your time, work in a clean area. Don't pinch the IP body sideways in a vise, The throttle assembly is a real bitch to get back into place, be patient.
I'm not really understanding what this phrase means; "Be sure you are on compression of cyl 1", I not getting the mechanics of what I need to do to. I assume its turning the Flywheel into a curtain position but then, how do I know when when I'm have it in the right position to avoid the "180 out" position? Are there any visual clues once the #1 Cylinder is in its correct position? @Ray70 used a similar phrase, "....( cyl. #1 on the compression stroke with "PC" aligned with the pointer on the flywheel )..." in this Post from a similar issue Thread, here, 2nd sentence...I was going to ask him the same question(s)......Be sure you are on compression of cyl 1 of you rely just on the PC mark you have a 50% chance (Murphy says 100%) you'll end up 180 out
You're absolutely correct about over thinking it. Sitting at the computer and reading everything is not the same as putting what I've read and what you guys have told me into practice. I think once at the Gen Set, doing it, it will probably become crystal clear...You are over thinking the operation. Take your time, and it will work out. And if you are 180 out, its simple to fix. Scooby outlined it. Its in the book. The first two times I did this, I didn't read the book, and had it 180 out.
Oh Geez...I just now saw the "Expand" button on this Post and for the first time viewed your responses to my questions which will definitely help.Questions:
It's funny, what you described is what I woke up this morning thinking about as one method of confirming where the PC mark is or should be...I was going to run it by you guys today, but you beat me to the punch...I will give this a try today.In that picture the valves on cyl 1 ( right side in picture.) are not correct.
Do this... determine which valve is intake ( left ) and which is exhaust ( right ) looking from the IP side.
rotate the motor until the intake opens and then closes.
Continue turning clockwise about 75 degrees ( something less than 90 degrees.
Stick your 1/8" drill bit in the plug in the base of the IP while pitting slight 1 finger pressure pushing in.
Continue rotating clockwise very slowly. you should feel the bit drop about 1/8" further into the IP right about at the 90degree point from where the intake valve first fully closed.
Look in the window and you should see the PC mark.
The TM explains the "A" and "B" marks on the flywheel and their relevance to the PC mark. I believe they are valve adjusting marks, but I don't recall off hand where they are in relation to the PC mark.
.It's funny, what you described is what I woke up this morning thinking about as one method of confirming where the PC mark is or should be...I was going to run it by you guys today, but you beat me to the punch...I will give this a try today.
The other method I was thinking about was to use the "Flow Timing" Method (2) described in the TM 34 and the Onan "Instruction Sheet"...I would try this method to simply locate/ID where the PC mark is or should be than remark that spot on the flywheel as the "PC". My thingking was, since the pump/engine were running fine prior to this current issue, both are, were timed correctly and that using either "Timing" methods would allow me to find or remark the correct location of the "PC"...but I could be wrong in my theory.
One question: How do I know when the valve(s) are open or closed? Are the Rocker Arm(s), on the IP side Up, Down or in the Middle?
Perhaps I'm misunderstanding you Rick, but wouldn't that be BDC on cyl #1? The intake valve closes somewhere around the bottom of the stroke, then rotating another ~90 degrees after the intake closes brings the piston up to the top of the compression stroke. Now it's at TDC.Rocker arms will be up for the valves to be closed! Something else to watch is if one rocker is coming up and the other is going down just as they reach the top then you need to go one full turn. You need both to be completely up and moving the flywheel a little in either direction will not move the rockers. THAT is TDC for that cylinder.
Okay...short version; Found the "PC" mark and its hash mark, turned the flywheel so the timing pointer was on the "PC" hashmark, 1/8" bit moves freely in and out of the IP's timing port and alignment hole of the face gear...Done. Ready to remove...YES??Stick your 1/8" drill bit in the plug in the base of the IP while pitting slight 1 finger pressure pushing in.
