So I was bored and built a turbo kit
AMG
94
13
Georgia
With the V12 V off getting a drive shaft made I had an empty garage and a moment to think…..
…..So I put a turbo on my other V, and it goes like this
Take one 998
Acquire 6.5 turbo manifolds for the princely sum of 175$
Go on marketplace and get a 6.0 powerstroke turbo (because whistle)
Utilize the plethora of piping I have laying around and….
My copes are all free hand and my welds are more along the lines of yes the metal is stuck together but don’t look at them but it’s good enough for the girls I hang out with
I’m using a 60mm gate to try to keep this 35psi turbo down to a level that won’t make the 40 year old 6.2 vomit parts out of all its orifices so that will be fun
I used the regular 6.2 drivers manifold and used half the 998 y pipe and half of a turbo cross over pipe, and its ugly but whatever
I’ll make the turbo oil lines tomorrow and then sort the whole getting the air into the engine thing
JimiT
11
Europe, Czechia
Take one 998
It's cool! Any update?
02smokemaker
34
moodus ct
How are you going to tackle the oil feed/drain? Looking good! I'm going to be building a turbo setup on my 6.5 but I'm going to mount in the v of the engine.
Sent from my NX769J using Tapatalk
AMG
94
13
Georgia
I did the oil feed from a T fitting off the back of the engine at the oil pressure sensor and I ran the oil drain through the fuel pump block off plate since the truck has an electric lift pump
TOBASH
3,770
Brooklyn, NY
Adjusted fire, swapped turbos
Runs and drives and makes turbo noises
I would strongly suggest that you go to a place like rubber duck or Mod Mafia and purchase a solid aluminum coolant overflow fluid container. Your turbo is very close to that plastic coolant container.
I might also wrap the turbo in some type of woven titanium to protect engine, wires, and hoses and pipes and such.
Your work looks beautiful. This is not a criticism. This is just me trying to troubleshoot.
AMG
94
13
Georgia
Had it out for about 45 minutes and it ran like a champ. It is however leaking oil something fierce, hopefully it’s just the pan gasket.
