- 4,501
- 4,395
- Brentwood, Calif
The tire now used is the Baja BF Goodrich…has been for quite some time, that tire I see is a 2017 date coded tire.What would you use instead Steve?
and thank you
and thank you
RWH if I could kindly ask you to share any and all safety information related to MT/Rs. I was under the impression that this sidewall issue was only for a certain year(s) of mfg, not every single one of them.The tire now used is the Baja BF Goodrich…has been for quite some time, that tire I see is a 2017 date coded tire.
This may or MAY NOT be the word or product... so read and determine one's own needs.Goodyear MT/R Tires Safety Message
I received a Safety of Use Message reference Goodyear MT/R tires older than 5 years. Govt has directed any of these tires over 5 years old (specifically Goodyear MT/R) get removed before operating due to sidewall blowouts. At least two accidents involving injury are attributed to this in...www.steelsoldiers.com
View attachment 939452View attachment 939453Some close ups of the window tolerances.
Yes. Removable. Brackets just add 14 degree tilt.Do the windows remain removable with the new bracket?
