Barrman
- 1,730
- Giddings, Texas
I needed more 55 gallon drums for my on going WMO works. Kwai wanted some barrels as well since I was making a run. I had no clue how many drums would fit in the bed of a M35, but I planned to buy up to 20 of them. Turns out that 28 will fit in the bed and barely be above the troop seats. 32 will fit with 4 being just a hair above the cab top.
I only had the money to buy 20, so 14 of them got neatly stacked in two rows while the last 6 just got stood up. If you look at the picture below, you can see how another barrel can easily be added to the current stack and still not be in danger of falling off. The troop seat support seen in the picture is the 3rd or middle one showing that 2 more rows will easily fit.
Here is a M35 tech tip. Even though you might hit your tires with a club or hammer and they sound right, use a gauge and make sure. My truck has covered more than 1200 miles in the last few months with no tire issues. They were checked in October when I picked it up in OKC. I just thumped the tires and they sounded ok since. Running to pick up the barrels last night I noticed a vibration that would come and go in kind of a pattern. I had changed out the brand new spare for the worn right front tire a few days ago, so I just thought it was that tire making itself round again. 10-15 miles later, I started wondering about some kind of drivetrain balance problem. So, I sped up to 56 from my cruising speed of 48. That didn't help, so I went down to 42 with no difference.
Loaded with 20 empty barrels, it didn't vibrate a bit going home no matter what speed I ran so I was convinced it was a rear tire out of balance or something.
I checked the psi today and found two of them less than 10. All were less than 40. I put them all up to 50 and went for a high speed run. SMOOOOOOTH is how it was. Check your psi every few weeks no matter how the tires sound when you thump them.
