goldneagle
- 931
- Slidell, LA
I would not have reduced the pipe diameter on the exhaust. There is a reason for it to be that size. Otherwise they would have used a smaller diameter to begin with...
the larger exhaust would lower the exhaust temps and possibly increase the boost. just my $.02that is true but I'm not going for max power that this turbo can produce, if I were I'd do a 5" stack and start saving for a new motor.
put a few hundred miles on the truck this week towing around my 19.5k lb M270A1 and man she pulls so nice now even with the big tires. I can hold my speed on any hill and EGT's pre turbo are under 1200 and boost is about 10psi.
? hua?How does the engine fit in the engine bay?
Did you have to make new engine mounts?
Does the flywheel and trans bolt directly?
