realm
- 5
- 0
- Memphis/TN
Bought my first M1009 from a very helpful gentleman on here, but have some questions I couldn't find answers to:
1) On the dash to the left of the steering wheel and down, beneatht he blackout switches I think, is a knob you can pull, that seems to open some kind of vent beneath the dash... what is that?
2) How can I tell if the trans, axles, etc. are the standard? This thing is geared so low I'm wondering if it's the M1008 drivetrain. I got up to 55-60 but it's screaming at that speed. Of course this is my first MV, but curious how to tell.
3) What's the life expectancy of a 6.2L and transmission? Mine has 100K miles.
4) What all do you recommend I check/do now that I'm the new owner? I know it has the powerstroke glow plug relay and new belts. What else do I need to check or replace? Engine oil, fuel filter, etc.
5) The 2 blackout switches... the one on the right I get. Service lights on off, or blackouts on, but what is the switch on the left? If I pull it out and try to rocker it up or down, it snaps back to the middle position and stays put. Is this switch worn out and what does it do?
6) Will auto shops work on these things when you break down or do you just have to tow it back to your house and you're on your own.
I'm no mechanic, but I think my plan will be to over time convert as much as I can to civilian Blazer setup so it's easier to find parts and so forth and get shop help when I need it.
