2009 vin info thread
KsM715
142
St George Ks
Sir just got my second truck.
M818 WO/W
A. C124 14101 (C124 is pre-printed on data plate, 14101 is stamped)
B. 05D-22471
C. 23200508984
D. GL Norman, Ok
E. 45 BDE-1-700 SPT BN A-77
Thank you,
Jeff
ctmustang
Thomasville-N.C.
hey CARNAC
I hope you can use this info.
id# 04p98971 053914751
stock# 23200771617
contract#daae0670c0001
bumper # hhc 125 may have been repainted
title has it listed as a 74 m35a2
thanks C.T.
CARNAC
The Envelope Please.
619
Corpus Christi, TX
To Mr. CARNAC
1970 M35A2 AM General
NSN-23200771617
VIN-0539 12823
REG-O4K37171
Purchased in southern nj from private seller
Thanks in advance:-D
AAAGGGGGGHHHHHH. Double beatings to you. Taking out the no spaces in the vin and an O instead of a 0 zero---pet peave #1.
Organization:1ST BN 112TH INFANTRY HHC Location:ERIE,
PENNSYLVANIA
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 W/W NSN:
2320000771617 Serial Number:
53912823 Registration Number:
4K37171 Year of Mfg:
1971
Usage Miles: 32400
May 07
CARNAC
619
Corpus Christi, TX
vin 1g8ed18j9ff187719
m&m CD-10516
2320011232665
reg NFOCLY
bought from gl ft bragg
1985 m1009
new club project. thank you sir, rtjraleigh
I thought this one smelled of bratwurst and beir. NICE, I was stationed in Mannheim many moons ago.
Organization:
69TH TRANSPORTATION COMPANY
GERMANY
Nomenclature:
TRUCK UTILITY 3/4TON Model:
M1009 NSN:
2320011232665 Serial Number:
J9FF187719 Registration Number:
NF0CLY Year of Mfg:
1985 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Information is pretty old Oct 85.
There is also an indication it was assigned to the 28th Trans Bn but no idea if that was a higher HQ for the unit above or if that was at Bragg. Some google work should clear that up for you. I think they are in Germany.
CARNAC
619
Corpus Christi, TX
CARNAC, can you research this please?
Vehicle info: M109A3
04B03871 0532 10757
31FSB B144
Mongomery, AL
Here is the problem: the frame serial number is 0532 10825
Can you get me the registration number and disposition of the frame serial number? This is the second truck I got from this unit where the data plate did not match the frame info...
Good job checking the frame. Technically that will be the correct SN and you can always get a dataplate to match it.
Organization:3D BATTALION, 117TH FIELD ARTILLERY REGIMENT Location:TROY
ALABAMA
Nomenclature:
TRUCK VAN SHOP Model:
M109A3 NSN:
2320000771636 Serial Number:
53210825 Registration Number:
4B64771 Year of Mfg:
1971
Info is from April 95
Oh and no space in the SN, now take one beating and be done with it.
CARNAC
619
Corpus Christi, TX
M818 WO/W
B. 05D-22471
C. 23200508984
D. GL Norman, Ok
Thank you,
Jeff
Organization:CO A,
700 CS BN, COMBAT SUPPORT
OKLAHOMA
Nomenclature:
TRUCK TRACTOR 5-TON Model:
M818 NSN:
2320000508984 Serial Number:
C12414101 Registration Number:
5D22471 Year of Mfg:
1971 Usage Miles: 63682
Mar 08 info
CARNAC
619
Corpus Christi, TX
hey CARNAC
stock# 23200771617
thanks C.T.
Organization:501ST SIGNAL BN AA DIV SIG BN M Location:FT CAMPBELL,
KENTUCKY
Nomenclature:
M35A2 W/W NSN:
53914751 Registration Number:
4P98971 Year of Mfg:
1972 Manufacturer:
65909
INFO SEP 05
AN ACTIVE DUTY VEHICLE FROM THE 101ST AIRBORNE (AIR ASSAULT) DIVISION.
SUGGEST VERIFYING YOUR FRAME NUMBER MATCHES YOUR DATA PLATE.
SORRY CAPS STUCK ON.
jerseyjello
Piscataway, NJ
PENNSYLVANIA Nomenclature:
M35A2 W/W NSN:
1971
Usage Miles: 32400
May 07
My Fault CARNAC, I was understanding it backwards!!!:oops:
All Apologies!!! Donation made!!!
Thanks Again!!!
CARNAC
619
Corpus Christi, TX
Hey, be happy, at least you have a good infantry deuce. At least it didn't belong to some band unit or a finance company or worse yet some JAG unit. I think I would burn mine to the ground or better yet send it to the bombing range if it were from that type of unit.
jimk
45
Syracuse, New York
Model - M813A1
Manufacturer - AM General
Vin (Frame) C1?? -10677
Vin (Data plate) - C136-10677 (3 is backwards)
Vin (GL paperwork) - C136-10606 (unreliable)
NSN (sticker on hood) - 2320000508913
Thanks to bazookajoe for going to Ft.Drum with me, reb87 for locating frame # and posting that info, Carnac for research, and Chris and Mike the great resources available here.
JimK
Biggles
Pawnee, IL
MANUFACTURER: AM GENERAL
NSN: 2320000771616
NOMEN: Truck cargo 2 1/2T M35A2
SN:052522189 CC:F
USA: 04H-71471 KEY:6165
DOC. NO.:W90QP8-8308-1001D
Came from Camp Dodge, Johnston, IA
The truck is Tan painted over the O.D.
CARNAC
619
Corpus Christi, TX
Model - M813A1
Fed stock# (data plate)- 2320-050-8913
Contract# (data plate) - 0669C0009
Purchased from - GL - Ft. Drum, NY - March 6, 2009
Frt Bumper R/L- 1-182-CAV / NLO??? (NLOKIF on both inner doors)
JimK
Screw the GL paperwork. Register it with what's on the frame.
Organization:182ND AR SQ 01 HHT RSTA SQDN I Location:MELROSE,
MASSACHUSETTS
Nomenclature:
TRUCK CARGO D/S 5-TON Model:
M813A1 NSN:
2320000508913 Serial Number:
C13610677 Registration Number:
NL01KF Year of Mfg:
1972 Manufacturer:
65909 Usage Miles: 17356
Info Dec 07
CARNAC
619
Corpus Christi, TX
NSN: 2320000771616
SN:052522189 CC:F
Organization:224TH ENGINEER BATTALION HHC Location:FAIRFIELD
IOWA
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
52522189 Registration Number:
4H71471 Year of Mfg:
1971 Manufacturer:
65909 :Usage Miles: 48241
Info Jun 87
Jinx
Buy me a Coke
124
Gainesville, Florida
a. Serial Number (VIN number)
b. Registration Number
c. NSN without dashes
d. Where you bought it
e. Bumper numbers if you can legibly read them
0525-21374
04G23671
2320000771616
USPFO in Draper City South, Utah
Passenger side bumper: ICA (possibly 1CA)
Driver's side bumper: HQ 108 4
Thank you very much sir!
CARNAC
619
Corpus Christi, TX
0525-21374
04G23671
2320000771616
Organization:USPFO ACTIVITY UT ARNG Location:DRAPER
UTAH
Nomenclature:
M35A2 NSN:
52521374 Registration Number:
4G23671 Year of Mfg:
1978 Manufacturer:
65909 Usage Miles: 7469
Info Nov 08
Prior to this it is listed with HHB 65th Field Artillery in Draper, UT. Might contact them about the ICA stuff.
Garlstedt
Grand Junction, CO
Info needed
Carnac,
M35A2
1. S/N 24073
2. Reg # Unknown
3. NSN # Unknown
4. Bought at Camp Dodge, IA
5. Bumper #: IANG 1034 CSSB
3655 C?? 641
Picking it up next week, so sorry I don't have more info. Thanks for the help!
cruzinz28
Maryland
M35a2
Serial Number: 04F-78171-0525-21088
Registration Number: ???
NSN Number: 232000771616
Where it was bought: Ft. Meade
Bumper Numbers: 260BDE372P 275P 49
DTID NUMBER: W74LS182620001A
Also, both dash data plate and the dash itself next to the data plate are stamped. "SWA". Not sure why? I will also snap a picture of those NATO batteries this weekend and get them posted. Thanks! - Jesse
dcthom3
Frankfort Ky
First Truck:
a.0525 17704
b. 04A-79671
c. 2320000771616
d. Boone Center, Frankfort Ky
First Truck:
a. Frame Number: M37926
b. 37926-4D0180
c. 2320000771616
