2009 vin info thread
CARNAC
The Envelope Please.
619
Corpus Christi, TX
Hi, again
I am hoping my hours of searching will turn up somthing on this duce.
If you type the nsn number in the search que it will take you to the information on that page
here in these doccuments.
TRUCK CARGO 2 1/2T M35A1 X40009 2320005425633 BM5 X X X X
Does the X mean expermental
http://www.usamma.army.mil/Documents/p738_750.pdf
Company Name: U S ARMY TANK AUTOMOTIVE COMMAND
AMSTA-IM-MM
CAGE Code: 19207
Status: A - Active Record
Parent CAGE:
Address: 11 MILE RD
P.O. Box:
City: WARREN
ZIP: 48397
CAO-ADP: S2305A - HQ0337
https://www.bpn.gov/bincs/choose.asp?cage=19207
https://www.webflis.dlis.dla.mil/WEBFLIS/pub/pub_search.aspx
I found this on SS and now I am really confused
Originally Posted by Duchess
Hi
Sorry new to these boards, hope this is enough info.
Could you please help with any info on a M35A1 wo/w
Fed stock no: 2320-542-5633
Vehicle id/chassis: M-57279
MFD by: 4E-0811
Think it was sold off 1989, no other numbers as very rusty :roll:
In need of lots of tlc!
Thanks Kindly
Kaz
No actual unit info but the unit code was WAP6F0 but the unit shut down and no information is available to say what unit it was. Here's what I do have:
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A1 NSN:2320005425633
Serial Number:M57279 Registration Number:4E0811 Year of Mfg:1962
Info date is an error out code from 2005. Actually surprised it is still in the system.
I am trying to get the original markings for this vehicle so I may paint vehicle to original specs as used by the Army....
I would like to thank all for any information avalible
:!::arrow::|:?::arrow::idea::arrow::p
OK, I sit here baffled as can be about what you are trying to accomplish with the info provided above. I guess you blew 2 hours of your life coming up with basically nothing. The info is general info about the M35A2 series truck.
X40009 is not some experimental code. It is the Line Item Number (LIN) for the 2.5 ton cargo truck without winch.
If your truck is missing the dataplate, then you need to find the number on the frame. The number you did find is not an Army serial number. It maybe a frame build number or something else but not a serial number.
Your truck is an M35A1 series truck that may have been brought to M35A2 standards. M35A1's usually have the serial number on the passenger side wheel well frame but there are exceptions. A2's on the driver side wheel well.
As for duchess truck info, I'm not sure why you would be confused about someone elses truck information? He had the frame number and got the information available.
CARNAC
619
Corpus Christi, TX
Yes! Just like if your truck was an M35A2 it would have the National Stock Number (NSN) 2320-00-077-1616. If it has a winch the last four numbers would be 1617 instead.
The NSN is the stock number akin to saying Ford F350 King Cab or Chevy Montecarlo.
OK, get a camera, go sit in the passenger seat of the truck. Just above the glove compartment there should be 2 data plates. Take a picture and post it on here. If the dataplates are missing, then look on the frame on the front passenger side wheel well. Since your truck is most likely an A1, it should be on the passenger side but there are exceptions. The number should start off as an M then followed by numbers.
frodobaggins
Ruston, La
Here is the info I have at hand. I can get more if you need, but it will be tomorrow.
VIN: NK0ESX062510086
Purchase Place: Shelby, MS
M35A2 WO/W
3dubs
Houston, TX
1986 CUCV M1009 all I have is the VIN# 1G8ED18J7GF194950 the rest was painted over. I bought it out of OK but was told by the site manager it came down from IL or somewhere up there.
Thanks
CARNAC
619
Corpus Christi, TX
M35A2 WO/W
Organization:HHC, 185TH AVIATION BRIGADE Location:JACKSON
MISSISSIPPI
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
62510086 Registration Number:
NK0ESX Year of Mfg:
1973 Contract Number:
DAA-E07-73-C-0232
Usage Miles: 10199
Info Nov 94
Prior to this it was with the 136th Signal Bn HHC in Temple, TX.
CARNAC
619
Corpus Christi, TX
Thanks
Nothing coming up. Better go back and verify the numbers.
oldiron4x4
Knightdale, NC
Would you mind helping me with identifying my first duece at your convenience. Thank you for your help.
AM General M35A2 Truck, Cargo: 2 1/2 Ton WO/W
DTID: W26L8F82190006B
NSN: 2320000771616
Dash Data Plat Identification Number: 82K94 and 082510238
Dash Data Plate Contract Number: DAAE0781C5307
Passenger Side Bumper Markings: 116 IBCT and 1/111FA
Drivers Side Bumper Markings: HHB9
Also, I can see stencils on the passenger side bumper under the paint the has 54F 1F11 or 54F IFII
I found a sticker on the inside of the glove box door that says rustproofed 6/82
I purchased this from GL in Blackstone Va.
CARNAC
619
Corpus Christi, TX
Here is the pic of serial and data plate and plate on bed...frame reads 2793 RA 112
OK,
Here is what you have
Unit Ident Code:
WHPMT0 Nomenclature:
M35A1 NSN:
2320005425633 Serial Number:
M61359 Registration Number:
NK0BN0 Year of Mfg:
1963 Manufacturer:
05827
Info Sep 05
The unit that your truck belonged to closed their doors and no long exsists. That's all I can do.
CARNAC
619
Corpus Christi, TX
NSN: 2320000771616
Organization:1ST BATTALION 111TH FIELD ARTILLERY 155SP PLT OP Location:RICHMOND
VIRGINIA
Nomenclature:
M35A2 NSN:
82510238 Registration Number:
Year of Mfg:
Usage Miles: 19909
Info Apr 02
usmarines72
California
M109A3
a. VIN: 0325-12279 or 0532-10743 (No dataplate, looks like 0325-12279 on frame,but window sticker has the 0532-10743)
b. Registration Number: NK0EGW
c. NSN without dashes: 2320000771636 (M109A3)
d. Where you bought it-Private sale (CA)
e. Bumper numbers if you can legibly read them- rattle canned out
CARNAC
619
Corpus Christi, TX
M109A3
Organization:US ARMY DEPOT LETTERKENNY Location:LETTERKENNY,
PENNSYLVANIA
Nomenclature:
M35A2 NSN:
32512279 Registration Number:
NK0EGW Year of Mfg:
1968 Contract Number:
DAAE06-68-C-0007
Usage Miles: 29857
Info Aug 92
Appears the truck was suppose to be turned in for rebuild. Not sure if it made it to rebuild or not.
frodobaggins
Ruston, La
MISSISSIPPI
Nomenclature:
M35A2 NSN:
NK0ESX Year of Mfg:
DAA-E07-73-C-0232
Usage Miles: 10199
Info Nov 94
Thank you sir :)
RNorris
Culloden, West Virginia
M35A2 year of Manuf. help request
I recently won an M35A2 w/winch, at GL and the deuce is located at Camp Dodge Iowa. The following is as much info as I can gather at this time and I need the year of manufacture for my insurance. Any assistance would be greatly appreciated.
AM General Corp M35A2 Truck, Cargo: 2 1/2 Ton W/Winch
NSN: 2320000771617
Serial Number: 0539-13909
Contract Number: DAAE0785CJ047
Passenger Side Bumper Markings: IANG (what I believe to be) 1034 QM
DATE OF MANUFACTURE: ?
gregary
wagoner, ok
CARNAC, help please, need vin for m35a2 NSN: 2320009260875, Reg # NK03RJ, Bumper info on the passenger side AR AR55, DTID W41MER82200021, Bought through gl at N. Little Rock 3/25/09.
CARNAC
619
Corpus Christi, TX
NSN: 2320000771617
Organization:227TH QUARTERMASTER COMPANY Location:FT CAMPBELL,
KENTUCKY
Nomenclature:
M35A2 W/W NSN:
2320000771617 Serial Number:
53913909 Registration Number:
4M84971 Year of Mfg:
1971 Manufacturer:
65909 Usage Miles: 51518
Info Nov 07
At this time it was supposedly sent to D Co, 1st Bn, 133rd Infantry, Iowa Army National Guard.
CARNAC
619
Corpus Christi, TX
Have you checked your frame for the LIN??
Nothing is coming up in the database using the provided reg #. I looked up the unit using the DTID and found that to be F Co, 2nd Bn , 211 Aviation in Little Rock.
Validate your serial number by checking the frame. Drivers side front wheel well.
