KaiserM109
- 4
- 0
- SE Aurora, CO
Help! I know all the issues and have intended to save my nickles up for a new Olympic pump, but I have to move my equipment starting this coming weekend.
On an M109 you have to drop the tank because of the bed, so mine is on the ground right now. I can put the bottom of the pump back together so that the hose goes to the bottom, which I would do if I was going to use an in-line pump. I know that it will run on the IP if I can get all the air out of the system somehow. Any suggestions on that point?
I really don't want to have to mount the tank and later unmount it.
I need a $50 solution (I am out of work), even if it is a working pull-out. I have very little trading stock except maybe some brake and bearing parts for an M101 trailer and an M105 trailer; Ford Bronco parts?
