Locked Military padlocks
1,132
I went to pick up a Deuce for a friend of mine recently and when I got to the ARNG facility where the truck was (a small local unit, not a big base), I hooked up the towbar and chains and when I went to put the transfer in neutral I found the steering wheel padlocked with the typical big chain.
Asking the Sgt. who was in charge if they had a master key netted the following response:
"rofl, we lost that key 4 or 5 years ago".
:shock:
Trailboss
138
Norwood LA
I've got 5 trucks and several lockable trailers. Each truck has at least one tool box and steering wheel chain (the M818 has two tool boxes), and I'm thinking of making the battery boxes lockable so I can use a battery terminal switch. That's too many keys to keep track of, so I use the combination Masterlocks that you can set the combination. All my locks have the same 4-diget combination that I can change anytime I want. I think I got the locks at home depot in 3-packs.
avengeusa
MI USA
i have a way to get them open and rekey them, i wish i could find a bunch more of them, i currently have about 4 or 5, all keyed alike, and used on all of my stuff, the steering wheel chain, tool box, motorcycles, and deuce fuel cap lock.....
emmado22
147
Mid Hudson Valley NY
There is a locksmith outside Ft Hood who redoes them, cut or not. You give him like 5 cut locks, he gives you 2 good ones with keys. No idea on contact info.
Pawnshop
23
Austin/Cedar Park Texas
Look on YouTube for "5200 lock" and you will find a video on "slipping", it's away to use a shim to get into the lock via the hasp, once in they can be re-keyed. As for the cut locks with keys, you can take the tumbler out and install it in other locks so they can all be keyed the same. When the lock is open look in from the top, that screw inside is what retains the tumbler. again YouTube shows how.
avengeusa
MI USA
slipping will work on some locks, but not all, some have double ball hasps, and the balls are locked into place with another part which rotates them into the hasp groove
KsM715
142
St George Ks
Thats what I use. Ive already got to many keys to drag around as it its.
Its nice to be able to open a tool box without having to track down the keys.
mudguppy
15
duncan, sc
I've actually snapped 5200 series with a BII Screwdriver and a adjustable wrench.. they are not that tough
it takes some technique, but was much simpler then signing for the "master key" from the motor pool or security.
no doubt - bolt cutters are way too hard to keep track of and store. grab an adjustable wrench and another around a 3/4" in size and they pry open w/ extremely little effort. or two around 3/4" in size.
btw, i used to order the 5200s in the packs of 10 w/ like-keying, so all the trucks/boxes/vans/etc. in my section were only one of 3 keys. i plan to do the same again - haven't looked into cost, but having one key that opens up all the locks on one vehicle is priceless.
Nonotagain
41
Parkville, MD
I have five American Lock Company pad locks, three 700 series of which one is a long shackle and two 5260 series locks all keyed alike.
What are they worth?
I changed over to Medeco high security locks with the cross cut tumblers.
avengeusa
MI USA
I get em for 15 each new....... thats for the gold colored 5200 series with a chain, not counting shipping, the 5260 is a shiny silver finish and can be had locally for 26 dollars, no chain
keyed alike is an extra buck or so per lock
what color are yours, and what do you want for them?
Nonotagain
41
Parkville, MD
These are silver.
Like I said I also have the three 700 series locks that are all keyed alike.
Never gave much thought to selling them.
avengeusa
MI USA
i am not sure what the 700 series go for, i think they are a better lock as in 2 more tumblers that the 5200 series.....
7000 series i meant......
Pawnshop
23
Slipping works on a 5200 according to the video. 5200 w/chain sell for $12 in new condition in the surplus stores in Killeen, I don't recall if they have any keyed alike.
avengeusa
MI USA
i just tried slipping a couple of mine, not working.....
also, on one of the vids a guy took one apart and mentioned the smooth pins, top and bottom, mine all have serrations, maybee i have the later models, the serrations make it a pain to get the barrels apart after removing them from the lock housing
i always slip the lock barrel once removed from the lock body when i do not have a key
Recovry4x4
LLM/Member 785
1,808
GA Mountains
At one point I had about 50 A5200GL locks. They went quite fast. I should have bought much more when I had the chance!
319
Lieutenant
57
Michigan
I have a limited quantity of Masterlock sets (2, 6 or 10 per set) available.
All keyed alike, with chains. Stamped U.S. SET. Key cannot be removed unless locked. These are new, not surplus. Approximately $12 per lock plus shipping . PM me if interested.
I'll post n the classifieds also.
