- 4,640
- 28
- 38
- Cambridge, Ohio
that will come in really handy when the power is out and you're hooking up your generator for back-up power
Divemaster,
That was a very good explanation of how to synchronize two power sources, but for all intents and purposes, the frequency isn't going to be that critical. Yes, the power companies are required to regulate the frequency of your incoming power to within very tight tolerances. But in reality, almost all of your modern appliances and electronics will work on either 50 or 60 Hz so if you use the gauge on your set and get the frequency close to 60 Hz (within 5% +/-...anywhere from 57 Hz up to 63 Hz) you're going to be fine.
Divemaster,
