... maybe you will learn to fear dangers like this. ...
this is what you got from my post? wow.
No problem. I appologize if you feel that I have directly offended you; the loose quotation in my post was in response to multiple postings in this thread by different folks and is never intended any more than a 'shoe-fits' kinda thing.
The point is this: if the advice as mentioned before of 'assuming the cable will break every time you use it' is followed, then the inference is that one would take proper precautions everytime. And if precautions are taken appropriately, it doesn't matter what cable is used - because you and I both know that a good quality cable can break at any time just like a poor quality one can because of undetected defects or other variables which is compounded when using a PTO driven winch.
So, sitting in the driver's seat and the cable breaks; are you saying that you are
not at risk of the cable recoil re-spooling onto your face with a good quality cable versus a poor one? Because by that logic, it's
never safe to operate the winch and people should always be 'afraid' to do so.
The fact is there is never 'zero' risk - 'zero' risk is an illusion.
However, people should not "
fear" risky operations and I would
never advise anyone to 'fear' something, because fear makes people do st
oopid things and is more likely to lead to an undesired consequence. Rather, a calm
understanding of the operation and what can happen,
respect for potential outcomes and consequences, and the
decision to take necessary steps to control and mitigate these risks in the event of an incident are the defining points between a successful opertion and one that is not.
I 100% agree with the point that you shouldn't use inferior products/parts just to save a buck - I never said anything to refute this. The cable that was posted as an example - I'd never buy it because there is no posted capacities and that vendor has a history of buying inferior imported junk.
I just don't think that the inherent risk to
any winching operations should be down-played just because you have the 'correct wire' - it's dangerous as hel
even with the correct wire and I believe that the comments made could lead someone to assume [the illusion of] safety just because of a certain part spec when there are so many other factors and practices that affect when an incident occurs and what the outcome will be.
Personally, I wouldn't use a junkyard cable, old and discarded one, one not designed for what I intend to use it for, or one that didn't have proper and comparable specifications and ratings by a reputable manufacturer or source. But if I can find something that fits my requirements and my interpretation of what is acceptable usage for the piece/part, I sure would like to save some cost so that I can buy a spare or replacement in the future - because nothing lasts forever.
