wehring
- 26
- 38
- Angleton, TX
Anyone put full airbrakes on a deuce w/5 ton axles yet? Any thoughts on the idea...
Justin Wehring
979 997 3112
Justin Wehring
979 997 3112
In most states you aren't required to have a CDL until the gross vehicle weight exceeds 26,001 pounds. A class B license is required if the GVW of the vehicle exceeds 26,001 lbs.hmm interesting idea.seems like alot of work probably be better to just get a 5ton.since you will need a cdl to drive it either way cuz of the air brakes
V-100s had deuce axles!anybody know what the deuce axles were used in BESIDES the deuce back in the 50 and 60s, i would guess medium duty dump trucks for one, if we can find the other uses, might be able to source the air brake set up
Same axle, no air brakes, just split hydraulic system.does the A3 use the same deuce axle, also is the it air
