full air brakes on a deuce
tm america
24
merrillville in
hmm interesting idea.seems like alot of work probably be better to just get a 5ton.since you will need a cdl to drive it either way cuz of the air brakes:roll:
Nonotagain
41
Parkville, MD
In most states you aren't required to have a CDL until the gross vehicle weight exceeds 26,001 pounds. A class B license is required if the GVW of the vehicle exceeds 26,001 lbs.
Can't speak for all states, but air brakes aren't an automatic qualifier for CDL.
I gave up my CDL a few years back but still have a class A "non commercial" license.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Years ago Memphis offered air brakes for deuces. Wouldn't it be a hoot to find a junk yard truck with them?
wehring
26
Angleton, TX
yup
Not a lot of work. It is one of my bobbers so the axle swap is minimal effort.
What is the motivation... 5.83 gears, factory air lockers and good brakes.
The reality of a truly streetable deuce is getting closer.
Justin Wehring
979 997 3112
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Don't they still sell them for the 800 series 5 tons? I think they are just over 3K.
tm america
24
merrillville in
i wonder if disk brakes with a split brake system would be better for the deuce than running five ton being that you loose some gear ratio to with the five ton axles.if you can get the 5 ton axles cheap and it doesnt force you into cdl in your state i say go for it .you will have to rework the air lines and brake actuator setup to
tm america
24
merrillville in
dont 5 ton axles have 6.44 or 6.14 ratios and a bobber is alot different than a deuce and should be noted so we all know what we are talking about
73m819
325
gainesville, ga.
anybody know what the deuce axles were used in BESIDES the deuce back in the 50 and 60s, i would guess medium duty dump trucks for one, if we can find the other uses, might be able to source the air brake set up
wehring
26
Angleton, TX
caught it huh...
Hehehe.... thought that would kick up some interest. There are commercial 44K toploaders that used the 5.81 ( I was wrong about 5.83) ratio. Drop in conversion.
Unfortunately I can not claim fame to this knowledge. Adam from adamsoffroad deserves the credit. He is a 5 ton axle guru... lots to teach.
Justin Wehring
979 997 3112
Recovry4x4
LLM/Member 785
1,808
GA Mountains
V-100s had deuce axles!
