My issue is more of a financial concern. It appears, "resellers" are selling the 003a for about $700.00 more than the 002a. The question is, is it worth the additioinal expense???
And just to confirm. the MEP-002a is 5kw and MEP-003a is 10kw?? Thanks again!
What are you loads? How do you heat, cook, etc? If you can get by with the MEP-002A -- then that is the better fit. Lower purchase price, less fuel, smaller, less weight, and less chance of wet-stacking. The 002A will run a window AC unit or two if needed as well. If you live in hurricane country, where AC may be "required", the MEP-003A will run most central AC units. Personally, where I live, we do get some nasty hot/humid weather in the summer, but I don't consider AC to be a critical load during an outage. The refridgerator and freezer, are. In the winter, heat is, as it is more than just comfort, it is keeping the pipes from freezing.
I used a cheapo box-store 5KW troybilt to get through the ice storm of Dec '07 that took out power for 24 hours (long for here), and it ran my well-pump, oil burner, circulator pump (hydronic heating from the oil burner, also feeds indirect hot water heater), and two refridgerators and a freezer just fine. I actually think that one of the MEP-016B/D (unsure which, listed as B, but have Yanmar engines, which may make them D) may fit the bill for me (rated at 3KW) that I just won on a GL auction. I got three of them for the going GL rate of a single MEP-002A. Plus at 440lbs, they are much easier to move around than the >1000lb MEP-002A. Don't get me wrong, the 002A is a great generator; I just think it might be more than I need. Now, If I can get a good runningn one for around $700, I'll probably buy it. That said, I did win an Onan DJB, which is a civilian 6KW set with a similar (but actually, smaller displacement engine), and a different (single phase only) head. I'm sure the DJB has less starting capacity than the MEP-002A, given the less conservative power rating of 6KW, and smaller (60cid, vs. 72cid) engine. I got the DJB for a little less than $500 at a GL auction two years ago. Now, that said, it isn't self contained like the MEP's. No frame around it, no skid, no fuel tank. It is meant for a permanent installation. It has a bad lift pump, but cranks over, and should run once I replace the pump (which I have). In two years, I haven't had time to get to this project of replacing the pump, and mounting it on a trailer, or frame with wheels. I did, however locate a Chinese-clone of a Yanmar-powered genset that runs run for $200. That is what I'm going to use if another storm hits before I get the MEP-016B/D units.
One other thing I like about the 016's that I'm getting, is that the Yanmar engines are quite simple. No lift pump required, no glow plugs required. I don't know if they 016 uses a lift pump or not, they might, looking at the fuel tank location, but I know that the Yanmars can be easily gravity fed in the event of a lift pump failure. I suppose that the DJB could be too, but I haven't tried. My goal is to get it up and running this spring. I don't know about the MEP's, but from what I understand, the DJx series Onans need quite a bit if preheat to get started when it is cold. The Yanmars (and even the clone that I have) will start relatively easily, even down into the single digits. They are a "cold-start" diesel with direct injection, and compression release.
Thinking of lift pumps, the MEP's do have redundent lift electric pumps (the DJx, mechanical ones that are a b***h to bleed), and as another poster mentioned, and aux pump to draw from a large fuel tank. If you heat with fuel oil, and your tanks are convenient to where you will run your generator, then you can connect one right up to your fuel oil tanks. I would use a top-draw line, don't connect into the line that comes off the valve on the bottom. This will greatly reduce the likelyhood of clogging your fuel filters with sediment.
In any case, read some other the other generator threads on this forum, as there is a lot of good information. If you are going to bid on them through GL, then if at all possible, try to preview the units you intend to bid on, and take notes (and even pictures). You will not be able to start them, but you can at least check for missing parts.
Good luck with your generator hunt, and post pictures when you find one!
