ok I am leaving Monday afternoon which will have me fighting the traffic in LA by about 8 pm. First thing tuesday morning I will be on base in Vandenberg. Here is my check list Please feel free to add comments or concerns:
chock wheels
remove fuel line from tank
open water seperator
remove secondary and final filter, clean bosses (are these canister filters?)
Blow fuel line back towards tank
reinstall fuel line and add 5 gallons of fresh diesel
install 3 new fuel filters (ANYONE GOT CIVI PART#'S, heard bad stuff about napa 3511&3512)
Check engine oil, and make sure oil filters are in place
check air filter, replace if needed
check coolant
check and tighten belts
check attachment of stop cable to injector pump
check front diff and knuckle boots
check master cylinder level
open air tanks
check tranny oil
check t-case oil
check center diff and axle seal
check rear diff and axle seal
push brake pedal 10 times hard and check for signs of leaky wheel cylinder etc...
Check circuit breakers(How do you tell if circuit breakers are good?)
make sure master switch is off and Eng Stop cable is out
install new batteries
If turbo motor pre lube turbo bearing
remove mushroom
crack secondary and final Fuel filter bleeder
master switch to "ON" (yikes) <img src="emoticons/icon_smile_shock.gif" alt="Shock">
standby secondary filter bleeder....close
standby final bleeder......close
master switch to "OFF"<img src="emoticons/icon_smile_shock.gif" alt="Shock">
get helper into position by mushroom
climb into cab and say small prayer<img src="emoticons/icon_smile_wink.gif" alt="Wink">
push in stop cable
tranny to "N"
winch control to "N"
check Volts
clutch pedal down feeling for free play
starter engage feather throttle
CHUG CHUG CHUG CHUG CHUG CHUG PPRRRRRRRRRR!!!<img src="emoticons/icon_smile_big.gif" alt="Big Smile"><img src="emoticons/icon_smile_big.gif" alt="Big Smile"><img src="emoticons/icon_smile_big.gif" alt="Big Smile"><img src="emoticons/icon_smile_big.gif" alt="Big Smile"><img src="emoticons/icon_smile_big.gif" alt="Big Smile">
Watch OIL PRESSURE for atleast a minute
squirt alcohol liberally into compressor while watching goop drip from airtanks...close airtanks
check around fuel filters and tank
generally look at every thing
After "low air warning" goes off and pressure is at or above 80LB stand on brake pedal, then get out and check for leaks
Thats my check list. Please make suggestions
Thanks Guys!!!
ps is the fuel pump fuse just a standard plastic plug in style?
