M35a2 paint job
cattlerepairman
3,355
NORTH (Canada)
You did a good job! Can you elaborate on the composite decking material that you used to re-do the troop seats and head rack? Brand, dimensions, price?
ranchand
Spokane, WA
I wouldn't use comp decking if you plan on using them. When its ripped and planed to those dimensions it is very brittle. Someones sitting back there, you hit a bump, SNAP!!!
Use white oak, mahogony or purpleheart, it wont break8)
Varyag
Garfield, Washington
I was very tempted to use the decking for my deuce. I was afraid of the warping factor to it. keep us posted how it holds up. My truck is about 90% complete with its paint job. I just took a wagner paint eater grinder to the original wood to strip it.
harry
Robbinsdale/MN
did snap bolts etc ,when put back to gether cut bolts flush to nuts helps wear on cargo cover
used composit decking think was Rino (what the local lumber company sells ), split down center (ended up with little bigger gaps between boards) , used router to round edges.
then old boards for drilling template ,then conter sunk , the head board needed to have edged made smaller to fit into sides,
all table saw cutting
stuf soaks up paint need to spray few times not as strong as the old oak but no slivers and think paint not going to peal
harry
Robbinsdale/MN
dont plane decking just conter sink holes a bit ( wood working tools should work )
was also worried about warping and saging , did decking summer before last no problems
and truck sits out side havent hade cargo cover on ,
Its not as strong as hard wood , for me it works
harry
Robbinsdale/MN
type 1 mosture cure no hardener use the two part primer, made to work together.
seems like stickey hard paint my shoes picked up some on grage floor ( painted some parts inside) took over week to wear off bottom of tennis
shoes (shoes picked up over spray on floor)
harry
Robbinsdale/MN
if your going to repaint the wood try this paint for a base coat you dont need primer and is some tougf paint you will need to pain over it when it drys for couple weeks its about 20 buck qt I used on other truck after sanding of old paint .
(Benjamin More Iron Clad Alkyd low luster Metal & wood ) the green looks like crap so you will need to pain over it
RAYZER
59
sanford/florida
carc 1
this is the same paint that im going to use on mine, did you use a standard paint gun? can you go over the original carc without using primer if you sand it? was this type 1 carc easy to work with? please post some more about this paint job experience!
