CUCV M1028A2 5.9L Cummins install
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
Hey all you CUCV fellow MVers Here some photos of Cummins Engine swap
still have TH-400 rebuilt to TH-475 HD Tcase NP205 with lomax gear set.
dual alt's 24Volt NippenDenso Starter Drive shafts up dated to 1410 U joint's.
Vote on it.
Thank you.
Ps I had Kuwait Crud when I did the swap 9 days. no help.
m818hayes
windham/ct
i love this thing, this is exactly what i want for an every day driver, awesome job! i would deffinatly like to see a video
of this thing rolling smoke down the freeway or boiling tire, SWEET RIG
mikeroot2
Argentine/Michigan
I saw this in person Sunday. The truck is bad arse! :drool: Nice workmanship/fab work. The Cummins look likes it belongs there. Strong running sweet sounding truck and it will definetly boil the tires! NICE WORK TROUTT!
m818hayes
windham/ct
well i'm glad to hear it, if i'm ever out in your direction i would love to see it, might be time to pack up the old 5 ton
for a road trip just to check it out
:driver:
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
There is no problems with RPM the Rear & Front Axle's been up dated to 3.07 Gear set's
Dana 61F Rear Dana 70HD.
AT 70 mph it is 1700 RPM.
Phily
IN
Vote on it.
Thank you.
Did you convert this from DRW to SRW? Did you get the D61 from a 1st Gen Cummins? What is the low down on the TH-475 HD?
Sorry for asking so many questions. This rig is bada$$
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Must have done something wrong, there is a big puddle under it in the first pic! BWAAAAHAhahaha, just kidding, looks great. Have you figured mileage yet?
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
The Dana 61 out first gen dodge cummins curb side pinion or under pass side
same as chevy.
The Trans has allison internal & tork converter pump repro valve body & govn.
This is been built for TH475 HD It still uses the trans VRV .
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
Fuel milage been 22mpg stop & go to 34mpg at 62mph exp at 70mph 27mpg
did fuel cal from 5 Gl fuel cell.
digitaldust
Twp Flint ,Mi ,
Yes this truck is VERY NICE all around. I have followed this CUCV for many miles in parades and running convoys. I'm thankful Troutt leads the way. The truck sounds very nice too
its very cool !
I My GF wants one now
1776
SW Florida
Very nice job! I like where you put the rear battery, I wish GM would have done it that way. Did you have any oil pan/axle clearance issues?
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
No none at all I bought all the adapter plate from Cummins.
also the engine is 5 degree tilt to curb side & 5 degree to the rear.
No clearance issues what so ever.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
With this install it was not that bad to get parts for it advanced auto parts Car quest &
Cummins most all parts in stock or one day away.
This was an fun project.
DigitalDust call me via Ph I have an extra personnel MNG SGT to run with us for next Convoy.
