This is what butch atkins said when I asked about lug nuts on a M211:
with the issue 30 inch bar and stud/lugnut wrench a200lb man bouncing on it can produce all the torque you will ever need to tighten these nuts,and if you doit yourself you will always be able to change a flat tire if yopu have to,saw an interesting sight at ga mvpa rally ,military air ratchets breaking sockets,5 foot cheater bars bending theissue 30 inch bar and lugnut wrench,double reduction ratchets couldnt break the nuts loose,moral of the story,ONLY USE THE ISSUE BAR ,STUD/ LUGNUT WRENCH WHEN TORQUEING YOUR LUGNUTS/STUDS,OR YOU WILL NOT BE ABLE TO REMOVE THEM WHEN YOU HAVE TO,next question ,tm 9-8024,page 472 pharagraph 259 inner nuts 400to 450 ft lbs,outer lugnuts the same,never let anyone put a 1inch drive air ratchet and socket to tighten your lug nuts,the military issued a WRENCH ,ORD PART # 7950644,and a HANDLE,wheel brng adj,and wheel stud/ lug nut wrench 3/4 in in dia,30 in long,ORD # 41-h 1541-10,fed stk # 5120-243-2419,page 7 ,ORD 7 SNL G-749,JUST HAD TO CHIME IN ON THIS ONE ,GOOD LUCK TO ALL ON THEIR PROJECTS
