- 6,961
- 2,468
- Montevideo/Uruguay
Very good! Although I think it could be more than a spring...I'm meeting with a guy today that can test these two ip's. It might take a few days but I hope to have an answer. It would be nice to find out that you swap out a spring in all our ldt's and then the injector pumps are the same.
According to the book the IPs for the 5ton engines (B & F codes) take the HD90EH101A hydraulic head (which is also interchangeable with the HD90EH111A, for the "A" code LDS465-2 engine). From the book again, the pumps for all C, D and E code engines (LD & LDT) are equipped with the HD90EH100A head.
I have found 5ton IPs installed in 2.5ton engines and working well, but they always had the corresponding "correct" HH installed.
Question now is: what could be the difference between both model heads and what happens if we cross-matched them? What I mean is that just swapping out a mechanical part of the IP doesn't convert the -100A head into a 101A, if there really was a difference in performance and not just the relative position of the fuel inlet hole, or such.
It sure would be interesting to know if and how the only replacement heads currently availabe (HD90100A, FSN 2910-828-7176) would work in a typical LDS 465-1A IP (#PSB6A 90EH 5828A1), in a LDS465-1A equipped Deuce!?
G.
