Lifting a Bobbed Deuce
USArmyMedic07
Bakersfield, CA
Dang, now thats what I like to hear!!! I'll call my local spring shop today and see if they can make me a pair for the front. I never though lift perches were the best way to go, but I know stack frames and whatnot isn't the best thing either. Lift springs would be my first choice!!! I've even got an extra set of trailer springs I could use.
THANKS!!!
Zak
Jakob
Louisville, KY
Any pictures of the front springs? I like the setup you have in the rear. I'm not a fan of block anywhere, but those trac-bars make it worth it.
Jakob
Louisville, KY
Don't mind me if I'm asking too many questions. It's my own way of showing that I am impressed with someone's work. I really like the setup you have on your truck and it's what I want to do with mine. Only I'm wanting to do a full length 4x4, instead of bobbing it.
mudguppy
15
duncan, sc
no worries, Jakob. i just really don't know if they are re-arched or custom packs. i know that they ride quite well. i do wish i would have opted for 8" rather than the 6". i recently gained another 1", but i still plan to trim the fenders some. not for street, but for off-road.
plym49
171
TX USA
you can get lift springs made. i have 6" lift springs in the front and 6" blocks welded onto the rear. the front rides great and the rear is firmly planted with zero axle wrap.
cavemantrucks provided the springs from a local spring shop.
I'm curious, is there any need for concern about the rear blocks parallelograming sideways?
plym49
171
TX USA
if they weren't welded, i'd say yes.
Is it possible that the welds could hold but the u-bolts or lifting blocks fail? Or a section of axle tube tear out? Even under articulation there is probably significant sideways force. In a slide where you then hit something hard, could the whole thing buckle?
I wonder if crosswise links or triangular gussets parallel to the axle would reduce the chance of that happening.
mudguppy
15
duncan, sc
Is it possible that the welds could hold but the u-bolts or lifting blocks fail? ...
no. u-bolts are much more flexible than welds. the welds would crack and fail long before the u-bolts. and the blocks are constructed out of very thick plate - i don't see these failing before the previous two components.
... Or a section of axle tube tear out? ... In a slide where you then hit something hard, could the whole thing buckle?
sure, anything is possible. there is plenty of room there and gussets could easily be added to increase the rigidity of the blocks from latitudinal forces.
with the relatively light weight of a bobber rear end, i think this sort of failure is extremely unlikely. if this were to be installed on a truck expected to see load, i would consider additional support on the rear blocks as mandatory. better yet, i'd probably go with full springs or air bags.
plym49
171
TX USA
Or, back half it? <kidding>
Thanks for not taking my comments personally. I understand your points, and since you have it right there in front of you, you are in a far better position to decide what it needs. If it were my bobber (not too far in the future, hopefully), in a case like this I would probably add a triangular gusset from the blocks towards the outboard side for my own piece of mind.
