USArmyMedic07
- 2
- 3
- Bakersfield, CA
I don't think the perch setup will be my weak point. If anything, it'll be that I'm only using One bolt to hold on each hanger.
i will try to remember to take a couple pics tonight/tomorrow.Any pictures of the front springs? ...
No, not a print. When I drew it, I laid it out on heavy card stock and cut out the shape. Then traced it on the 3/8" plate, and sheared it on the lines.Did you make a print when you made your brackets for you lift
I'm curious, is there any need for concern about the rear blocks parallelograming sideways?you can get lift springs made. i have 6" lift springs in the front and 6" blocks welded onto the rear. the front rides great and the rear is firmly planted with zero axle wrap.
cavemantrucks provided the springs from a local spring shop.
Is it possible that the welds could hold but the u-bolts or lifting blocks fail? Or a section of axle tube tear out? Even under articulation there is probably significant sideways force. In a slide where you then hit something hard, could the whole thing buckle?if they weren't welded, i'd say yes.
no. u-bolts are much more flexible than welds. the welds would crack and fail long before the u-bolts. and the blocks are constructed out of very thick plate - i don't see these failing before the previous two components.Is it possible that the welds could hold but the u-bolts or lifting blocks fail? ...
sure, anything is possible. there is plenty of room there and gussets could easily be added to increase the rigidity of the blocks from latitudinal forces.... Or a section of axle tube tear out? ... In a slide where you then hit something hard, could the whole thing buckle?
I wonder if crosswise links or triangular gussets parallel to the axle would reduce the chance of that happening.
Or, back half it? <kidding>no. u-bolts are much more flexible than welds. the welds would crack and fail long before the u-bolts. and the blocks are constructed out of very thick plate - i don't see these failing before the previous two components.
with the relatively light weight of a bobber rear end, i think this sort of failure is extremely unlikely. if this were to be installed on a truck expected to see load, i would consider additional support on the rear blocks as mandatory. better yet, i'd probably go with full springs or air bags.
Tool boxes are like shop space never can have enoughI don't think you have near enough tool boxes.![]()
