Ruppster,
Thanks for responding! Sounds like you have been at this for awhile and have done a fair amount of homework.
After the $600 fine fron NC I learned not to trust even the word of a Commercial LEO. That's when I started doing the research myself. The last cross country trip I did with a semi truck and trailer was from Alaska to Florida when the Air Force PCS'd us to MacDill AFB 12 months ago. Trying to research Canadian requirements was a royal pain. I thought the regs in the U.S. were bad but they took it to a whole new level.
I see your just down the road from me, (I’m in Polk County) so we are both in FL. which works out great for me since I can just “Copy your homework” J
Cool, another Florida member. Welcome to SS. There are quite a few members in the Tampa/St. Pete area along with a few others around Lakeland and Orlando. If you need an extra set of hands working on an MV let me know.
I do have a couple questions based on your responses. See below.
Only a couple?
FL requires all 10k+ vehicles to weigh? I hauled more than that in my 1 ton with a trailer hundreds of times. Your telling me I should have been stopping? So that means pretty much any 2.5 or 5 ton MV must weigh unless registered as an RV? So in a MV instead of “Not for hire” maybe “Registered RV” would be better? (Assuming of course it actually is registered as one).
I just spent the last hour or two trying to find the reg on this but have not had any luck yet. The info I mentioned is what I have been told by two different FL DOT agents. And yes, they told me one ton trucks are supposed to stop but turn a blind eye to them. If you have an M109 that has been converted to an RV then putting "Recreational Vehicle" and "Not For Hire" on the doors wouldn't be a bad idea. I've seen this done with several antique trucks.
Since you have done the Florida homework, exactly what is involved in making the conversion to RV from MV? Would it be the same deal if going from commercial 18 wheeler to RV hauler?
I called the main FL DMV office about reclassing a truck to an RV and they said I would have to talk to the local tax collector's office in my county. IIRC you had to have sleeping facilities along with one of the following two items installed, either a 120 volt electrical system or a seperate heating or air conditioning system. If you had either one of these done by an RV shop all you had to do was show them a bill for the work. If you did it yourself you had to sign a statement that you did such work. No visual inspection was required. But this is what my county tax collector told me. I would recommend you call the tax collector for your county and ask them to make sure.
I know the RV style is smaller but I have not paid enough attention to know, can you use the 18 wheeler size 5th wheel hitch to haul a RV (I mean will it all fit and work, not a legal issue here) I am assuming on a load capacity issue alone that even if it fit you could not use the RV hitch to haul a 18 wheeler trailer?
Won't work directly but from what I understand they sell adapters that will let you tow an RV with a commercial fifth wheel hitch. But I have not looked in to that issue so I don't know for sure. Might be a moot point though as when I went to get a Toterhome insurance policy on my International I was told it could not have a commercial fifth wheel hitch. It had to be a RV style or I could not get insurance unless it was a non-commercial commercial policy.
So…. In Florida, if I (No CDL) were to go out and buy a 18 wheeler tractor (And have a CDL holder drive it home for me) and hook it up to my 5th wheel RV (Need to change the hitch to RV style/size for proper fit/function first?) then I can drive the assembly all I want? But if I drop the trailer in the campground and try to drive the tractor to the store, now I have a problem? And just as importantly, I DO NOT have to stop at weigh stations? (“Florida” - Over 10k must weight in any case?)
Correct, no CDL required when the trailer is attached as the combo is classed as an RV (even if the tractor is not). As far as weigh scales RV's are exempt in Florida.
Assuming that I can drive the assembly in Florida (and I am Florida licensed and the rig is FL registered) then all the other states have to recognize that as well?
Pretty much. While some states may require an RV classed license in their state they have to recognize legal licenses from other states. So if you have a vehicle that is registered as an RV in one state they have to allow it in another.
Is the (Florida) process for registering what was formerly a commercial 18 wheeler tractor to RV use any different than the Florida process for registering a MV?
No difference as you are doing the same thing, changing it from one category to another. So the process is the same.
Assuming I wanted to get a Florida CDL to cover me when driving either a MV or 18 wheeler (for personal, non-commercial use) Which CDL do I need? What does it take to get that? Cost? Renewal process?
This is a gray area. An M35/M109 are under the requirements for a CDL so no, a CDL is not needed for them. But you may need a Class B CDL if you tow a trailer with a M35/M109 as this will put you over the 26,000 pound weight rating mark as a combo vehicle (unless trailer is an RV). I say "may need one" as I have not looked in to this aspect. But a 5 ton 6x6 will need at least a Class B if it is a tractor version. If the 5 ton is a cargo truck and not a tractor then it is exempt from needing a CDL. At least in Florida it is. A first time CDL costs $75 and then $75 for each renewal. Don't know if there is a fee for the road test itself though. To take the road test you need a truck that falls within the requirements for a Class B license (i.e. the truck has to have a GVWR of at least 26,001 pounds or more).
Lastly, say I get a M916 (or a used commercial 18 wheeler tractor) and a commercial 18 wheeler trailer (probably a reefer) and build what is obviously a RV in the style of a toy hauler (garage in the back) inside the trailer – In Florida – how do we license it to our best advantage? Can we make it an RV? Does the un-hooked restriction apply?
The truck will most likely have to be registered as a truck but the trailer can be registered as an RV after you finish the conversion. I've looked in to doing this myself as a way to get around IFTA/IRP when driving out of state to antique truck shows. My idea is to take a drop deck trailer and build RV type sleeping quarters in to the front half of the deck. Then the back half of the trailer could be used to haul another truck. With this combo yes, the unhook restriction applies (unless you get a Class B license, but if you do this out of state IFTA/IRP come in to play).
Although not a MV, it might be interesting to purchase a used 18 wheeler and make it a 6x6 and pull a converted reefer trailer. Can you put super single tires/wheels on a “regular” commercial type 18 wheeler?
If you use a military 6x6 or a commercial 18 wheel converted to 6x6 you will have to keep an eye on your fifth wheel height. It might be too high for use with a civilian trailer (i.e. once you add the height of a civilian trailer to the height of the fifth wheel on a 6x6 you could be over 14 feet high overall). You might have to look for an older 12 foot, 6 inch high trailer (current trailers are 13 foot, 6 inch) or better yet use a military trailer in the first place as they are meant for use with the taller fifth wheel height of a 6x6 tractor.
As far as using super singles yes you can. They even sell super singles for 18 wheelers. The military 5 tons and 10 tons even use the same lug nut pattern used by commercial trucks. The trick is you have to watch out as there are two types of rims, hub centered and lug centered.
On another note you might want to read the following web page as it has some info about overall vehicle lengths in Florida when it comes to RV trailer combos.
Florida DOT- A heads up! - Honda-Tech
Hope this helps. If I missed anything please let me know. I can be reached by email via my profile it you want to contact me that way.
Ruppster
