Unforgiven
- 18
- 0
- Las Vegas, NV
Instead of doing a power steering swap or a full-hydro conversion, has anyone considered a hydraulic ram-assist piggybacked on top of the stock Deuce manual steering?
It seems that would be a viable solution to power steering without even touching the original setup.
A bolt-on steering column adapter, once calibrated, could meter the hydraulic fluid to the ram. It could even be calibrated via a sort of rag-joint setup to give hydro before the manual effort was required.
In effect it would be full-hydro steering but with the security of the manual system left fully in tact and functional.
