331
Claymont, DE
I had to move mine down to a friends farm because county code enforcement decided to get on my stpfather about thunder and my stepfathers motor home, for now till I find somwhere closer its parked next to my buddys deuce on a farm, lol.
Trust me, ill be up someones rear at county code this week, 4 acres of land and you can't keep your own stuff there? Someone is gonna get an earful :twisted:
Seth_O
Sac CA
Degreased and pressure-washed the engine today, and adjusted the e-brake. Still need to fix the soft-top and make a run to the dump. Not in that order.....
Castle Bravo
Hundredaire Socialite
218
Arizona
Did the yearly fluid check.
Transmission Oil
Transfer Case Oil
Front Axle Oil
Middle Axle Oil
Rear Axle Oil
Checked the engine oil, radiator coolant, brake fluid, and tire pressure as well, but I do those more than once a year.
Ditch Baby
Palm Bay FL
last two weeks-
New/old
-hood
-door-
-wire harness, front and rear
-paint
-two brand new windows
-just finished getting the air t-case mounted about 30 mins ago.
still need to put the new exhaust on, finish up the t-case swap, put the dash back together, replace a bad wheel cyl
srodocker
68
Lacey, Washington
NICE! had to explain to the gf what a tractor pull is. I took the truck to the buddys place and planned on working on it or my camper trailer and found on the ebrake spring is gone. and then looked around and chatted it up. face is sunburnt from 55 degrees woohoo! good times
VP17IFT
Chancellor/AL
Changed the oil and filters without making a huge mess, now waiting for seats i bought off ebay to replace the "comfortable" stock seats.
RGS20inophir
10
Socorro, New Mexico
Pressure washed the deuce and picked up a new inner and outer axle seal in preparation to replace the blown rear seals on the curbside. I also attempted to add a quick coupler to the manifold on the passenger side of the firewall. When I removed the nipple coming forward out of the manifold I found that the thread was NOT 1/4 NTP. The thread is WAY finer.
eagle4g63
34
North/west Indiana
I drove it to the gun range today!!! Took the highway and rolled about 60mph the whole way(first time over 30-40mph) love this truck!
Shot the s*&t more with everyone about it than I shot my guns:grin:
monkster
Mt.Vernon, IN
Pulled out a buddy's tractor w/ the winch. He was try to recover his 4 tx, got it out, bu t his tractor kept sliding into his lake. Glad he tried not fight it to long as that his lake is spand ass full from all the rain we have had. They (corp) have put anther foot on the ohio.
Armorsolutions
Heber UT
Added a fuse block for 12v in the cab. Wired a couple cig lighters to charge phones, etc. Also hard wired a streamlight rechargeable flashlight and installed new 12v electric wiper motors. Good weekend!
