First attempt at replacing metal
Katahdin
24
Scarborough, ME
Finally took the plunge and got a mig welder two weeks ago, after playing around a little bit this was my first attempt at patching a rust hole. The project was the driver's side fender.
Of course everything got a bit more complicated once you got into cutting the metal. I originally thought I could get away with patching it in two places, but a couple spots were too pitted/thin to weld and then found I some rust sandwiched between two sheet metal panels. In the end I welded in 5 patches.
A couple times it burned through, of course, so I used a piece of aluminum behind the area I was welding to prevent that. The steel does not stick to the aluminum and helps dissipate the heat.
On the pieces of metal that were back-to-back, I sprayed on weld-through primer. I also employed magnets to hold the metal in place where I needed. Welding wire was .30, which came with the welder, I understand .25 might be a better size for sheet metal and less prone to burning through because it carries less current. Gas was C25. Welder was a Miller 211 using 110V. I played around a bit with the voltage and wire feed speed as I work on the fender, being a newbie I just couldn't leave that alone. Other tools was a grinder and angle grinder with cutting disks. Thick cutting disks on the angle grinder were also good at grinding down the welds.
Worst mistake was cutting the large patch a little too narrow, it was a PIA to fill in the gap, I won't make that mistake again.
It took a good part of a day to do this, but I enjoyed it and with any luck my skill will get better. :-D
Katahdin
24
Scarborough, ME
Yeah, I agree. Initially I thought I could get away with just the one large patch but then had trouble welding it in on those sides due to the pitted metal or hidden rust, so i had to cut it back some more and make more patches.
Beerslayer
55
Tualatin, Oregon
That turned out good. Nice work. Were you thinking to use some filler to smooth it out or are you going to just paint what's there?
Katahdin
24
Scarborough, ME
Thanks and yeah, I already slabbed it with filler, I plan to sand it down and prime the entire fender this weekend.
The perspective I'm taking on the rust is its practice: "Honey, I need to go practice some more on the deuce so I can do a really good job on your car..." :smile:
Well, at least her car is green...
Dave Kay
29
Kingman AZ
Hey now, I'm with you on this thread, hope to see the finished results!
Looking to do some welding/panel-mating myself. Got 2 stepside beds that are beat to hekK with the front parts of one in good shape and parts of the other the rear is in fair shape--- but niether as a whole. So in my newbie mind, I'm thinkin' maybe I can 'Frankenstien' all good pieces together to make one decent bed... (feel free to shoot me down here anytime...)
Anyway, that's the plan, is it feasable?
Katahdin
24
Scarborough, ME
Thanks nk14zip, I hope to get it to the Maine rally!
Dave - I saw a tank restoration TV show where they took two bombed out Shermans and welded them together in a similar fashion. Also saw an episode of Trucks where they took a C-10 longbed, cut it up, and made it a shortbed. Enough time, patience, skill, I think it can be done. Of course, this is coming from a newbie so take it for what its worth. ;-)
ranchhopper
139
south elgin illinois
Nowdays with the newer epoxys and resins on the market they make an epoxy thats just as strong as welding parts together I was a skeptic too until I saw the end results. You can cut your bad metal out and flange the hole and epoxy the patch in it works great no heat warpage I will use this method on the next restoration I do.
flyxpl
9
Chatham IL
Another advantage to panel bonding adhesive is that when panels are welded on you have bare metal that cannot have corrosion protection put on it . With the adhesive all your covered up bare metal is coated with adhesive , no bare metal to rust . Although a mixture of fiberglass and plastic a Corrvette is glued together .
zout
154
Columbus Georgia
K - look up a flanging air tool that has the punch on the oposite side of it - very cool tool to assist in these type of panel weld - laying a repair panel inside a flanged piece makes them flush as well.
Good job first time
Dave Kay
29
Kingman AZ
Thanks K, and as a total fabrication newbie I would've hardly believed some of the mating panel work that's been done until I sat and watched a whole segment on American Chopper where a guy did similar work to fenders and fuel tank. Amazing finish and not a ripple in sight. With some experience, I figure it can be done and like you, I'm game to try.
Hope to see more of your work and good luck!:beer:
Katahdin
24
Scarborough, ME
Here's the results after sanding down the lightweight body filler and a couple coats of primer. Looks a lot better then a rust hole!
Thanks Z, I think I've seen those but didn't make the welding connection. Another tool to add to the shopping list!
One new tool I tried on this job, besides the welder, was an air powered orbital sander. Now wished I had that earlier on other parts, it was comfortable to use and got into tighter spots then the DA sander I had been using.
FYI, I'm just sanding down the carc before priming, I don't have the time to remove it all and want to make airborne as little of it as possible (I do wear a paint respirator). On the rubberized undercoating I used a small needle scaler to remove the loose stuff.
Katahdin
24
Scarborough, ME
Looked to me the fender skin was 18 gauge, but the structure material was 16 gauge.
I used 18 gauge scrap metal from an old desk my Mom had me haul out of her basement last year. I figured it would come in handy when I started to toy with welding. I couldn't find 18 gauge at Tractor Supply, Lowes, or Home Depot, so having the scrap metal on hand worked out great. It sometimes pays to be a pack rat.
Katahdin
24
Scarborough, ME
Thanks, Maddawg. It took me a long while to tool up to get this far. I had made a long term plan for my wife's MGB restore: First purchase an air compressor, then the air tools, and finally a welder. Somewhere along the line I got distracted and bought a deuce--that set me back at least a year!
whyme
angola ny
Couldn't agree more. I've been hoarding old metal bed frames, I use it all the time for various small projects and patch work around the yard. Steel is getting had to come by and expensive to buy.
