Floridianson
- 2,512
- Interlachen Fl.
For those of you still having problems did you change all filters, check all lines (suction and return) for dammage and working correctely. Check intank pump for correct pressure. check IP fuel pump pressures at the different rpm's. Check to see if you engine can even get to 2600rpm no load?
Check turbo and air filter for free and clear air to move and running some good clean diesel.
Would have to agree that we might not be able to get much boost down low as said not much air moving.
