rattlecan6104
- 7
- 0
- Oak Harbor, WA
So a couple weeks ago I was talking to a few coworkers about how the rear suspension worked on the deuce. as we were standing next to the truck I had noticed that my leaf springs were farther away from the frame than they should have been by about a couple inches. I removed the dust cover to find the two spindle nuts and lock washer were just sitting in the dust cover and the tapered bushing was riding on the trunnion threads. The lock washer had only one of the 6 tabs bent down, and it looked like it was done right. Prior to this I have never taken that dust cover off, never had a need to.
I got it to a nearby friends house and jacked up the truck to see how bad the damage was... I nearly had no threads left. I had to acquire a new trunnion, and jack up the truck by the frame, remove all 8 rear wheels, the leaf spring packs, the lower dog bones, and the spring perches, meanwhile supporting the axles all before I could remove the trunnion. In the process I cleaned up a few parts and gave them a quick coat of primer and paint to help protect them from corrosion.
When I acquired the replacement trunnion, I noticed it had tapered roller bearings in it they were manufactured by timken with part #392. Since two of them were essentially toast and my tapered bushings were still good, I just kept the bushings.
At this point I would like to say the method I used to support the frame worked... HOWEVER, I DO NOT RECOMMEND THIS METHOD, we were very fortunate the ground was stable and the truck did not shift. In hindsight this could have really ended severely badly. I have heard there are jack stands tall enough to support the frame, if anyone has a source for them they could provide that would be great.
I urge you guys to take the five minutes to check your rear trunnions on your deuces to prevent yourself the hassle that happened to me.
