markehle
- 2
- 8
- Dowling, Michigan
I am going to turn up the adjustment screw on the FDC on my duece and the heater makes it really hard to get to it. Would it make more sense to remove the FDC, adjust it, then bolt it back on?
Also, I have some questions about the adjusting. When you hold the outer nut and turn the inner one in, after you are done is there supposed to be space between the nuts, or does the outer one lock the inner one? Right now there is no space at all between the two, and it makes it look like the outer nut is just a lock nut.
Thanks!
Mark
Thanks!
Mark
