blakeke
- 0
- 1
- Montrose, PA
It seems to me that a deuce on the highway would only need 2 wheel drive with an open diff for better fuel economy, is there a way to change an ARB air locker on one of the rear axles from an open/locked to a free spinning/locked. That way you could have 2 wheel drive with minimal scrubbing, then if you need traction you could lock in the rear 2 diffs (maybe with the same air that engages the transfer case). If you needed a bit more than that lock in the front lock out hubs for an open diff on the front and locked rear diffs. I'm not a mechanic or an off road guy, but my deuce loses traction a lot when I'm in the woods, and that set up, if possible would seem both convenient and good for on road handling and mileage. Just locked rear diffs would get me plenty of traction 80% of the time I bet, if I was feeling rich I could replace the front diff with a locked one, but it seems a lot of money for the one front wheels worth of traction, if it comes down to that I'd perhaps be using the winch anyhow. Or do 2 open ARB lockers on the back not effect mileage enough to be worth the bother trying to modify one?
