I've got 33/12.5/15 Firestone Destination M/T's on my stock wheels. I have a 2 inch rough country lift though. I dont THINK these tires will fit because of the aggressive lugs( they will be fine for on road use, but you MIGHT run into some minor rub when you're at full tilt). However, not all 33's are truly 33's. These firestones are 32 5/8 tall. If this is strictly a pavement queen, you can probably get away with a A/T 33 inch tire. Like the fellers said before me, a lot depends on the condition of your springs. My springs were tired and wore out. The 2 inch suspension lift springs are exactly flat when the vehicle weight is on it. The stock springs are about an inch reversed...
The 2 inch lift was well worth it IMO. My springs were SHOTTTTTT. My 09 rides like a cadillac now that I have new springs and tires!
http://www.steelsoldiers.com/cucv/65439-m1009-before-after.html
1. What size/brand/tread 33" tires are you using? Firestone Destination M/T 33/12.50/15
2. How would you rate the road & offroad performance? Off-road performance is great. On road-they are noisy. noisy is an understatement!
3. With stock gearing, were your disappointed with acceleration/perfomance? Not at all disappointed. Because of the increase in tire size, my MPG on the highway went from 22 to 23.5-24 MPG! I know it isnt much, but that little drop in RPM at highway speed (62-65 MPH) will save ya some $$ in the long run.
4. Was any tire rubbing evident? Did you trim the fenders? N/A
5. Please share any other words of wisdom you feel is relevant.
