uniquify
- 217
- 43
- Sioux Falls, SD
For the past several months I've been on the lookout for some extra outlets that could be added to a MEP-802A or MEP-803A easily and seamlessly. Recently, I came across a watertight L14-30 twist lock receptacle (Hubbell HBL2710SW) that was a close match to the cover above the right rear tie-down ring.
I say close match because the bolt holes for that cover are 3" on center, and the bolt holes on the outlet were 3 1/8" on center. I decided that a slight modification to the MEP was tolerable and proceeded to use a small file to stretch the holes. The goal was to remove just enough to material to accommodate the outlet, but not so much that they couldn't be hidden by the original cover if I decided to remove the outlet. There was also a clearance issue with one of the bolts that holds the tie-down ring. I probably could have cut some threads off the bolt to make room for the outlet, but I took the easy route and just flipped it over so the nut is outside the enclosure.
Don't forget to attach the wires to the outlet before bolting the outlet to the generator. I used some 8 gauge wire that was left over from a previous project, but 10 gauge would have been good enough for 30 amps.
The original 4 bolts from the cover were about 1/4" too short to fasten the outlet to the generator, so I had to grab some longer ones.
Once the outlet was bolted in place, it was straight forward to connect the wires to the lugs.
I'm happy with the way it turned out. It's compact, waterproof, took maybe 15 minutes to install, and it let's me get full power out of my 802.
Hope this helps somebody!
-Eric
-Eric
